Seeley Honda Exhaust
Has anybody got an original RSC exhaust for a Seeley Honda 200 in an intact state which I could buy as a pattern? Or one that I could measure ?
I've just bought a Seeley Honda but all the original exhaust mounting brackets on the frame have been removed and I need to reference the correct position of the brackets.
The exhaust system now on the bike follows similar lines to the original RSC item but now attaches to a bracket that hangs from the rear suspension top mount, which isn't a bad solution really except I'm not sure how the middle box will behave if it is unsupported. I wouldn't be concerned but the middle box fouls the rear tyre on full compression and is also touching the base of the airbox. If I go to the trouble of modifying the existing exhaust to clear everything properly, or make a new one from scratch, I might as well replace the frame brackets at the same time and return the bike to standard.
Many Thanks
Why not buy one of the Stainless exhausts often for sale on ebay? They are made to fit the original mounting points.
Yep i could make one if you want!!
hi there!
I have a genuine exhaust on my bike, if you want I'd take a pic and post it or send it to your e-mail you should tell me
cheers
f
Did you know that if you text "Seeley" into your mobile with predictive text on......it comes up as "Reflex"...how weird is that !!!!! :thumbup:
