headsteady
hi all dose anybody know were i can get a stronger hesdsteady?
  • Replies 40
  • Views 16.7k
Most Popular Posts
  • I was working on my 340 last night so whilst the tank was off I took a couple of pictures of the alloy head steady. I can't post photos on here so if someone who can will PM me their email address I'
  • nigel dabster
    nigel dabster
  • nigel dabster
    nigel dabster
    T
for what?
for my sherpa 350T 199A
Why do you need a stronger headstay?
What happend to the one you have, did it break or do you think it will break?
The standard one that came with the 199A is just fine IMHO.
they were pants, which is why the later 199b's had the ally one.
They are out of steel, look here, detail left, mounted right:
%5C%5CMISTER-BINAER%5CServer-Anwender%5CPatrik%5CBultaco%5C2010-12-12%5CDSC07872.JPGBultaco%20Limaseite%20links%2003.jpg
Just work fine?
Read my post, the later 199b's.
I have read your post, there was NO other headstay mounted than the one made out of steel.
Maybe someone installed an other unit to Yours or one of the last reminding workers, - still employed in line with the welfare program that was initiated by the goverment-, that wrenched the last Bultocosbikes together from the remaining parts that where available in the factory was tired of searching and mounted what he found.
If you have any doubts, ask Orlando Colander, he is one of the last remaining importer of bultaco
motorcycles und parts and he is still in business too! -> www.orlandocalondersa.com
Otherewise show me the part number ... there is none I know
Later headsteady from a 1982 199B 340
thanks my dear hewson, perhaps we can share the apology?
What you must take into account, (are you in the usa?) sometimes you cannot swap a parts book for specialist knowledge.
It may well have been an outsourced supplier who didn't get paid and someone decided to make the steady they always needed but it was a factory part fitted to the late 340's, period.
I haven't written / said that it is impossible that someone changed the design or the headstay.
But as I know there is no offical parts book and no offical photo around showing this bracket.
Nevertheless the aluminium bracket is an improvement, because you don't have to bend the steel one down or loose one
head nut + one head screw to get the headstay detached for more space to get f. ex. the engine removed.
Juast as a reminder: the bikes build after the bancrupty of Bultaco where somekind special because the executive board wasn't involved in the production.
BTW:
Some Bultaco riders don't even mount the headstay, (Here the T199B EX Fred Michaud):
Just work fine?
hi thanks for your photos ive got the headsteady on it was just awkward getting it on ill post photos when ive finished ive just got me wheels whats the best tape to use for the inner rim?
The standard pressed steel bracket will break if the bike is ridden in any sort of reasonable competition, if it is not repaired the frame will begin to bend, the backbone bends upwards and the front downtube bends inwards and hairline cracks will start in the downtube at the bottom engine mount and at the junction of the top triangular gusset and the downtube. All the 199B bikes I have seen have had the pressed steel bracket, so I would really like to see a detailed photo of the late factory alloy one fitted with the tank off. When I have seen photos of some english bikes with them fitted I just assumed they were a comerfords modification.
Cheers Greg
Edited by sherpa325
Cheers Greg
Yep, totally right, to avoid any overstraining to the headstay it is necessary to mount the complete cylinderhead / headstay assambly together.
Bending the headstay down for getting the engine better out of the frame is a bad idea, (you will overstress the steelplate, which later will cause that it cracks). Just unscrew only the two fastenings of the cylinderhead for getting loose the headstay is also not recommended, you can "wrap" the head.
This is the problem of this kind of bracket.
BTW:
Why the headstay is not mounted to Mr. Michauds former Bultaco is a miracle to me.
BTW:
...........because you are totally missing the point!!!!
It may well be that fred's bike had the steel one and it broke, or more likely the frame top tube was bent and leaving the steady ooff allows it to go back.(NB depends which way its gone i have seen both)
lots of things went "unnoteded" during the last production runs perhaps you would know from the parts book which bikes had motoplat and which femsa ignitions as both were fitted to 340's? of course not. The alloy steady was fitted by the factory the bikes were not modded by comerfords.
