Number Plates
I'm in the process of registering the Gasser.
How do you guys that ride road trials mount a number plate??? :wacko:
Any piccies???
Cheers in advance......
I created a weird and wonderful mount that bolted through the rear light and hung down, but it's A*se!!!!
Rubs on the wheel eventually and wore through today. Mind you it's lasted about 8 months.
Everybody uses sticky yellow plates on back mudguard.
They're not strictly legal (well they're not even loosely legal) but neither was mine and theirs are much neater.
I was making a best effort as I was on 9 points for a while, but sod it, I'm back down to 6 and going for the sticky yellow plate.
I use yellow Fablon bought from a local hardware store, buy small stick on letters & figures then stick it on rear mudguard
I suppose if you see a copper behind you, you could just do a constant wheelie, therefore enabling him to see your number plate?? :wacko:
Not done mine yet but will be mounting one of these under the mudguard (they weigh nearly nothing & cost
Edited by PokenH00D
Right heres the cost effective way
Create a text box in microsoft word
type in reg no and colour the box yellow then print out (you could use yellow paper if youre posh).
cut out and stick to mudguard with whatever you can see in your garage!
finally water proof with something Ive used yacht varnish before!!
Or you could laminate it at work (that is if you can).
You would be surprised how long the varnished version lasts up to 3 months if you wash carfully!!! :wacko:
Ian
Hey PokenHOOD, are you the same guy that posts on the SM forum at visordown.com?
Oh yeah :wacko:
Highland 950 SM
Montesa Cota 315R R4
How ya doing?
I'm doing fine, small world (wide web) eh?
KTM LC4
Scorpa SY
I see you're from Worksop too? I was born there, moved to Tickhill when I was four and lived there 'till I was seventeen.
Edited by boofont
KTM LC4
Scorpa SY
It's a very small world mate, i used to work in Peterhead :wacko:
(thread highjack!!)
boofont!
what towhitch have you got on your vectra?
i got a sri140 saloon, and need a hitch for it, only really want a detachable one, but how does yours look? is it a big ugly looking thing? is it a goose neck one? if so, how does your bike rack fit on it?
(highjack over - no need for a trip to guantanamo bay mr.bush!!)
I had a vectra with a Witter bar on it. Not too ugly at all, it was the wife's car, so it had to be fairly unobtrusive or I wouldn't get away with it :D
I don't think you can fit a bike rack to a goose neck, but I may be wrong.
Edited by bikespace
I suppose if you see a copper behind you, you could just do a constant wheelie, therefore enabling him to see your number plate?? :D
Stu,
thats the last thing you want to do! :D
My tow bar is a standard traditional one, not a goose neck type. The rack has a box section that bolts between the tow hitch and the main towbar brackets. To us the rack you just slide in each end of the rack and then bolt through the rack and box section.
