May 30, 201115 yr hy iv got a pw50 for youngen but its frame and wheel are abit tatty whats the best way and what paint to buy to spray paint the frame and wheels regards ste
May 30, 201115 yr get em done in two pack be done in a couple of hours and will look mint see my tank was done in 15 minutes
May 30, 201115 yr Author get em done in two pack be done in a couple of hours and will look mint see my tank was done in 15 minutes that looks really good what prep work do i need and do i need primer ect also where do i get two pack from regards ste
May 30, 201115 yr that looks really good what prep work do i need and do i need primer ect also where do i get two pack from regards ste Be aware that 2k paint is very dangerous, it contains isocyanide I get some decent results with cellulose paints Edited May 30, 201115 yr by Monty_Jon
May 30, 201115 yr Author can this be done via spray can also what is needed to prep and where to buy im after a gloss black like your frame
May 30, 201115 yr go to your local paint supplier and they will mix and put it in an aerosol tin to what you want,but you will be beter using cellulose+ it drys quicker.
May 30, 201115 yr Author go to your local paint supplier and they will mix and put it in an aerosol tin to what you want,but you will be beter using cellulose+ it drys quicker. i dont no anyone local any other ideas
May 30, 201115 yr i dont no anyone local any other ideas I use a small HVLP spray gun its very good for bike parts, you can get the cellulose paint off ebay or a local paint supplier Use anti-bloom thinners & jet-black paint for the frame. Make sure you prep well with wet & dry and a good coat of primer first Use a spray gun like this, better than cans and lasts years! gun Edited May 30, 201115 yr by Monty_Jon
May 31, 201115 yr try your local motor factors,if they dont have they should be able to tell you where.
June 5, 201115 yr Personally I'd get it powder coated. It's a little more expensive than having it painted, but I had my Beezer frame done in 1992 and it's still good. As has been pointed out, 2 pack is in fact deadly dangerous. I'd avoid using it without proper safety kit.
June 6, 201115 yr Dye29, i see your at Scarborough, If you dont mind a bit of travelling, Rhomax at stockton will powder coat the frame for approx
June 11, 201115 yr Author Dye29, i see your at Scarborough, If you dont mind a bit of travelling, Rhomax at stockton will powder coat the frame for approx
