October 28, 201115 yr Hi all hope someone can help ,I have a 97 montesa cota 315r which I'am trying to rebuild the engine on I can get all the parts except a conrod kit.Apparently honda only supply a full crank at god knows how much!!! Has anyone rebuilt one themselves or know someone who can? I've heard the engine is similar/the same as a cr 250, is it ? ANY HELP WELCOME thanks in advance Kev
October 28, 201115 yr Hi all hope someone can help ,I have a 97 montesa cota 315r which I'am trying to rebuild the engine on I can get all the parts except a conrod kit.Apparently honda only supply a full crank at god knows how much!!! Has anyone rebuilt one themselves or know someone who can? I've heard the engine is similar/the same as a cr 250, is it ? ANY HELP WELCOME thanks in advance Kev Hi , no the engine is not the same or even similar to the cr250, you shouldnt have problems with parts try sandifords honda/montesa or pidcocks honda
October 28, 201115 yr Author Cheers all the other parts came from sandifords but Iam afraid I dont wish to deal with them again but will try pidcocks. still not sure if they will supply a conrod kit but I will keep looking as I cant stretch to a new crank yet
October 29, 201115 yr Hi , no the engine is not the same or even similar to the cr250, you shouldnt have problems with parts try sandifords honda/montesa or pidcocks honda So was it just an urban myth that the cr250 had the same 315 bottom end?
October 29, 201115 yr i think the the clutch plates from one of the MX bikes fitted, maybe people jumped to a conclusion from that ? I think Honda only sell cranks for the MX bikes from memory but you can probably get aftermarket con rods, hopefully one will fit the 315 ?
October 29, 201115 yr I think there's a very good chance the rod kit is the same as *some* Honda. There are lots of rod kits available from good aftermarket places and you can get there basic specs. Here are the basic specs of a cr250 rod from Wiseco: Material Type:
October 31, 201115 yr They are not the same mate i researched this for a friend some time ago all the cr250 rods are too long!there are some very close matches ie; old ktm rods but i never found a perfect match. the complete honda crank is
October 31, 201115 yr I thought that was quite cheap! in comparison the sherco 250/290 crank is £486 That's because your a time traveler, where everything is more expensive in the future ! You need to adjust you clock, or TC does. Edited October 31, 201115 yr by B40RT
October 31, 201115 yr That's because your a time traveler, where everything is more expensive in the future ! You need to adjust you clock, or TC does. i dont get it
October 31, 201115 yr Hereabouts its only 7.17, but I always have been accused of living in the past ! Edited October 31, 201115 yr by B40RT
October 31, 201115 yr Hwereabouts its only 7.17, but I always have been accused of living in the past ! I guess you think my pricing is dated thanks for explaning yourself in a mature manner ,
