AVGAS
steam
Increasing the octane will likely cause a loss of power
I noticed my 07 is a bit sensitive to fuel, if it's even 2 weeks old I get a detonation at higher rpm with mid throttle openings
Fresh fuel is a lot better but is still has a minor tendency to ping
Richer on the needle helped a bit, I will try richer on the main, I suspect it's just the wrong needle or needle jet that is the cause
