nakednutt Posted May 26, 2012 Share Posted May 26, 2012 Whats the best replacement clutch to get for a 315 and where do i get it? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
nakednutt Posted May 27, 2012 Author Share Posted May 27, 2012 also i've been using putoline light gear oil. is this ok or would atf be better and how often do you change the oil? Quote Link to comment Share on other sites More sharing options...
nelly1 Posted May 27, 2012 Share Posted May 27, 2012 i have been using that oil for ages with no problems Quote Link to comment Share on other sites More sharing options...
nakednutt Posted May 28, 2012 Author Share Posted May 28, 2012 anyone recomend a clutch? Quote Link to comment Share on other sites More sharing options...
clay Posted May 28, 2012 Share Posted May 28, 2012 Not sure if this helps bud, But i replaced just the steel plates with dimpled plates from B,V,M. as mine was grabbing, and thumbs up for the putoline (hope you get some more feed back) Quote Link to comment Share on other sites More sharing options...
nakednutt Posted May 28, 2012 Author Share Posted May 28, 2012 thanks clay. i'm looking to change the full clutch. Quote Link to comment Share on other sites More sharing options...
manofsteele Posted May 28, 2012 Share Posted May 28, 2012 I've just fitted a complete clutch from offroadmotouk on Ebay. It was a generic unbranded thing, I had a punt simply because it was cheap. I can tell you that after fitting it I can now push the bike around in gear, something I absolutely could not do before. Haven't ridden it yet though, so we'll see. I'll keep you posted. Regarding gearbox oil, I use ATF myself, dextron III. I buy it by the gallon from a motor factor (cheap) and I change it every other ride. Never hear owt bad about the Putolene light though. Quote Link to comment Share on other sites More sharing options...
nakednutt Posted May 28, 2012 Author Share Posted May 28, 2012 i cleaned my clutch and it was rideable but still dragging for 3-4 outings but its back to dragging bad again. Quote Link to comment Share on other sites More sharing options...
tlrmark Posted May 29, 2012 Share Posted May 29, 2012 i cleaned my clutch and it was rideable but still dragging for 3-4 outings but its back to dragging bad again. Thats why everyone changes the steel plates to dimpled ones, it fixes the dragging issue.If you replace your clutch plates with the origonal fibre plates it wont help at all. These bikes had this issue from new. Replace the steel plates with dimpled ones (aftermarket) leave the origonal fibre plates in (never seem to wear out) and problem solved. Quote Link to comment Share on other sites More sharing options...
nakednutt Posted May 29, 2012 Author Share Posted May 29, 2012 Thats the answer i was looking for. Cheers Quote Link to comment Share on other sites More sharing options...
nakednutt Posted May 29, 2012 Author Share Posted May 29, 2012 anyone any experience with the apico plates from bvm? Quote Link to comment Share on other sites More sharing options...
clay Posted May 29, 2012 Share Posted May 29, 2012 anyone any experience with the apico plates from bvm? yep, fitted the apicos in mine, from b,v,m and dremeled the bits of glue from between the fibre plates, remedied the drag. and made neutral possible, just (keep changing the fluid) Quote Link to comment Share on other sites More sharing options...
nakednutt Posted May 29, 2012 Author Share Posted May 29, 2012 will let you know how i get on. cheers Quote Link to comment Share on other sites More sharing options...
andy2565 Posted May 30, 2012 Share Posted May 30, 2012 hi i'm quite new to trials and found out the hard way about the clutch drag,when i stuck it in gear for the first time and hurtled towards the car in front of me,so i read alot about with lots of views,so i decided on renewing the steels and fibre plates with the apico type from bvm,i also cleaned the grooves out of the fibre plates {a very time consuming job}and oil i used was the p1 clutch tuner,and i have been out twice now and its great,but one point which i had read about previously was that the apico plates are slightly thicker and when the clutch is pulled in fully the pressure plate rubs on the inside of the case,not sure on how to rectify this,i just got into the habit of not pulling it all the way in until it wears in a bit,can't beleive the messing it requires though. Quote Link to comment Share on other sites More sharing options...
clay Posted May 31, 2012 Share Posted May 31, 2012 hi i'm quite new to trials and found out the hard way about the clutch drag,when i stuck it in gear for the first time and hurtled towards the car in front of me,so i read alot about with lots of views,so i decided on renewing the steels and fibre plates with the apico type from bvm,i also cleaned the grooves out of the fibre plates {a very time consuming job}and oil i used was the p1 clutch tuner,and i have been out twice now and its great,but one point which i had read about previously was that the apico plates are slightly thicker and when the clutch is pulled in fully the pressure plate rubs on the inside of the case,not sure on how to rectify this,i just got into the habit of not pulling it all the way in until it wears in a bit,can't beleive the messing it requires though. Havent noticed or heard any rubbing with mine, might be down to the leaver adjustment,try a rebleed, and a tamber with the clutch leaver, (your right about it being time consuming, get the dremmel on it) 100% better Quote Link to comment Share on other sites More sharing options...
