February 14, 201313 yr Hi, I recently got a 315 mont, bike seems really good starts well hot or cold, plenty of power etc but it sounds a bit crappy on idle, like its running out of petrol which it isnt. I have cleaned the card properly using carb cleaner and an air line a couple of times. The air filter is fine, like new and properly oiled, its got the correct plug with the correct gap so all the "usual" suspects are fine when checking for this sort of problem now im a stuck. What else can i do to try and solve this problem? Cheers.
February 14, 201313 yr This sounds like the least of your problems, if your name is anything to go by !
February 14, 201313 yr My mates 315 is exactley the same, we've cleaned the carb,new plug etc, it also knocks as if its lean so going to try super unleaded, it may do the trick! If anyone knows of any other issues that will help, please reply. Edited February 14, 201313 yr by jam
February 14, 201313 yr Had similair problem with my 314R , have you tried adjusting the fuel screw out a bit. I set mine up as per the manual and it would'nt tick over. Found a link on this site somewhere with a video of a Gas Gas dealer from the states stripping the carb (dellorto) Followed his directions and its runs perfectly.
February 14, 201313 yr Author Thanks for the info. The link to the carb setup would be great if anyone has it. Luv u long time!
February 18, 201313 yr Thanks for the info. The link to the carb setup would be great if anyone has it. Luv u long time! Icy smile !
February 26, 201313 yr Took a long time to find but this is the link i mentioned - http://www.youtube.c...&v=1EbXacjIV78#!
July 17, 201313 yr When you said you cleaned the carb, did you check the pilot jet was clear ? What fuel oil ratio are you using ?
