nomisrelda Posted March 13, 2013 Share Posted March 13, 2013 Hi, Newbie here! Just got back onto a bike after 20 years or so, (2004 Gas Gas Raga 250) ............. Wow ! Things have changed since trying stuff on Yamaha DT's! So just come back with a big grin, having run out of gas, refilled with first tankful since delivery, and now its peeing out of carb bowl overflow. Stops when tap turned off. So I guess its a bit of **** on the float valve. Or can it just be sticking?? Or have I over filed the tank??, I know nowt about Gas Gas!! Any advice before I pull the wrong thing apart?? Thanks Quote Link to comment Share on other sites More sharing options...
b40rt Posted March 13, 2013 Share Posted March 13, 2013 Sometimes floats stick, gently tap the float bowl and it might be ok. Failing that , clean the carb. Quote Link to comment Share on other sites More sharing options...
zippy Posted March 13, 2013 Share Posted March 13, 2013 Welcome back to motorcycles, sounds like you are enjoying yourself. If you did not have fuel overflowing out the top of the fuel tank you did not overfill it. and if you did there is no big problem other than you have fuel all over your bike. There is no special level in the fuel tank, they are still just basic fuel holding tanks like years past. If the floats are stuck you may be able to tap the float bowl with the handle of a screw driver and "free" them up. The title of the thread reminded me of a fuel can I saw at an event that made me chuckle. On the side of the can it said "Gas Gas Gas" Quote Link to comment Share on other sites More sharing options...
zippy Posted March 13, 2013 Share Posted March 13, 2013 b40rt, Ya beat me to it!!!! 1 Quote Link to comment Share on other sites More sharing options...
nomisrelda Posted March 13, 2013 Author Share Posted March 13, 2013 Thanks for prompt response guys! Had tapped it gently...... and the a lot less gently! Will go get spanners out. Quote Link to comment Share on other sites More sharing options...
zippy Posted March 13, 2013 Share Posted March 13, 2013 Good luck Quote Link to comment Share on other sites More sharing options...
lee99780 Posted March 13, 2013 Share Posted March 13, 2013 Do you mean all time or just with engine running? Quote Link to comment Share on other sites More sharing options...
jse Posted March 13, 2013 Share Posted March 13, 2013 Sometimes floats stick, gently tap the float bowl and it might be ok. Failing that , clean the carb. That usually will fix it. Another common problem is that someone may have "adjusted" the tab that limits the float arm drop and the arm is down too far, which can cause the float needle valve to get cocked in the valve bore and the carb bowl will flood. Jon Quote Link to comment Share on other sites More sharing options...
gasthatchgas Posted March 14, 2013 Share Posted March 14, 2013 Check that the carb is sitting level....if its cocked to one side it can cause it to p*** out Quote Link to comment Share on other sites More sharing options...
nomisrelda Posted March 14, 2013 Author Share Posted March 14, 2013 Carb seems level, have 'tapped' carb, bounced bike a few times, but as soon as tap is on, it p*** itself. So will go clean carb. But I did notice that the drain spout 'bulge' on the bottom of the carb, seems to be slowly hammering through the gearbox casing, as it vibrates! Is this 'normal'? Maybe I'll araldite a small metal plate under it, or wedge a bit of inner tube? Quote Link to comment Share on other sites More sharing options...
sting32 Posted March 14, 2013 Share Posted March 14, 2013 If you have the delorto carb, there are 2 vents, one on each side of the carb... A neat and tidy "hosing trick" was used: where a single hose goes under the carb to both sides to these vents. BE AWARE, that the bottom is cut or opened, under the carb so it "vents." Without this cutting or opening under the carb, it is NOT vented. Dont ask me how we know... you could have used 2 separate hoses, but they don't at the factory either. Quote Link to comment Share on other sites More sharing options...
nomisrelda Posted March 14, 2013 Author Share Posted March 14, 2013 All sorted! Dunno what was wrong, no visible c*** in it. Popped off float bowl. Pulled out valve, looked at it! Put it back together. Now fine!! Thanks for all the input. Quote Link to comment Share on other sites More sharing options...
zippy Posted March 15, 2013 Share Posted March 15, 2013 All sorted! Dunno what was wrong, no visible c*** in it. Popped off float bowl. Pulled out valve, looked at it! Put it back together. Now fine!! Thanks for all the input. You gave it the "Evil Eye" and told it to shape up and fly right! You must have a formidable "Look" Quote Link to comment Share on other sites More sharing options...
