May 20, 201313 yr I have recently bought my first classic twin shock trials. I believe its a montesa 349. Frame and engine numbers both start with 51M. Im wondering if anyone could help me identifying what year it is?
May 20, 201313 yr 349's with the 51M code were manufactured between 1979 and 1983. Can't tell what you have with so little information. Go to www.montesaweb.com and match your 349 with the correct year.
May 22, 201313 yr What color is the tank? Is the tank fiberglass or plastic? What color is the frame? Here's what my late 1982 / early 1983 looks like (plastic tank):
May 25, 201313 yr Beauty....................I've a 81 Ulf Karlson replica..............white. Does anyone have pitcures of ther REAL ULF Karlson 349...............I mean the works bike. My project is to make a real replica.
May 31, 201313 yr I've just begin to "put things in place". First thing is the bar.................I'll put a Renthal 5.5 Second thing probably, rear shocks................any advice??? NJB or Magicals??
November 16, 201313 yr Heres a picture of my 349 i bought it of john reynolds its a 1981 and is pictured with john riding it in the scottish i also believe that rathmell had an identical bike. just found your post hope this helps.
November 23, 201312 yr That's a great pic of a lovely bike. I have tried to make a replica myself. [/url] Will probably put the original silencer back on as it's not quiet running right yet.
December 13, 201312 yr That's a great pic of a lovely bike. I have tried to make a replica myself. [/url] Will probably put the original silencer back on as it's not quiet running right yet. It wont do with that WES on it. I tried one, and it went straight on ebay, choked the motor and it wouldn't rev!
December 15, 201312 yr Interestingly I had that exact problem, took it out today with both silencers, much better with the standard one, hmmmm, may take it apart and see what's inside.
December 15, 201312 yr Hi there, The late model 349 and MH349 definitely run better with the heavy standard rear box. I have a virtually unused WES back box somewhere in the loft. The standard rear box has a baffled first chamber and an absorption second chamber. The first chamber can be heavily blocked with carbon and oily gunge. With care the standard rear box can be cleaned and repacked without having to reweld it.
