tightwoods Posted September 16, 2013 Share Posted September 16, 2013 Which company makes the best electronic ignition for a 199A? Thanks! Quote Link to comment Share on other sites More sharing options...
bultoboy Posted September 17, 2013 Share Posted September 17, 2013 Bultaco uk hands down Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted September 17, 2013 Share Posted September 17, 2013 is it adjustable? Quote Link to comment Share on other sites More sharing options...
bultoboy Posted September 17, 2013 Share Posted September 17, 2013 Not sure. I bolted it on 5 years ago and it is still going. I think you can adjust it by rotating the back plate but you would have to ask dave renham or one of his colleagues. 1 Quote Link to comment Share on other sites More sharing options...
guys Posted September 18, 2013 Share Posted September 18, 2013 I just mounted this one on my 159, works perfect. Isn't cheap but comes with a lighter flywheel which makes the throttle response a bit quicker.. After I installed it as the instructions said, I checked the timing with a strobe light and it was perfect. http://www.francetrialclassic.com/en/ignition/1280-bultaco-trial-electronic-ignition.html Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted September 18, 2013 Share Posted September 18, 2013 perfect at what mm btdc? Quote Link to comment Share on other sites More sharing options...
guys Posted September 18, 2013 Share Posted September 18, 2013 perfect at what mm btdc? Between 2,5 and 2,7 mm Quote Link to comment Share on other sites More sharing options...
