Should My Starter Shaft Move Like This? (Video)
http://youtu.be/9O93JWXvBB0
Took the bike out today and it started making rattly noises, sounds to me like the piston but when I started looking ive noticed the clutch cover is cracked around the starter shaft. So two questions:
1. Should the shaft move like this, if not what do I need to fix it?
2. Could that have been the noise I heard that I thought was the piston?
Edited by sawtooth
  • Replies 33
  • Views 8.3k
Most Popular Posts
  • Just an "alert" about moving the kickstart forward! take a good look at the bikes on some gasgas website, try to match where they are from factory on your bike. Reason? because the bikes USE the FO
Looks okay to me as the case holds it when on. Ive stripped a few Pro engines n taken paw out n replaced it.
Not sure what you mean? Since posting this ive got the engine out so whats the quickest and easiest way of finding out what the rattling noise was? Is there an easy way of checking things like the piston and crank etc?
Also if the starter shaft play is OK how come the case cracked?
Hoping to have it fixed by tomorrow night so help really appreciated!
If I'd lost a bit of oil due to the cracked cover, what damage would that have done to the engine, anything that would be likely to cause a rattle?
I'm leaning towards the starter shaft idler gear (is it?) from reading online, apparently it can cause a noise that sounds like an engine rattle, how do I inspect this and change it?
Edited by sawtooth
I think it might be the pawl gear as I have had the kick starter jam up a few times, I take it thats clutch basket out and I should be able to see from there?
Edited by sawtooth
when the bike is running and in neutral does the noise disappear when you pull the clutch lever in?
No not really. Its not the usual clutch rattle.
Edited by sawtooth
idler gears get rough. if a "part" like a tooth gets stuck to clutch basket teeth, then it can bend the clutchbasket slightly, so check all gears from crank to idler for big nick or gouges.
the PRO bikes, early on have too much leverage on the case, I know one guy bought 2 cases on a bike, they both broke. I have had 6 bikes from the 04's up to- 2013 Raga. Never broke the case. My sense/opinion is kicking it the incorrect way? also was that the "non aluminium case" it is weaker, so alum case will be better and weldable if it comes to that. since the 08-to my 12, they all have that non aluminium case (cant think of the word/type).
Lastly I have NOT tried to move my shaft like you have, there is a BEARING that the shaft goes into, mine (changed the kicker gear and idler a few different bikes) seemed to be somewhat tight, when in place like is supposed to be, make sure you have a "shim" and all shims, for that matter in place, while looking at parts breakdowns from gasgas?
Edited by sting32
Ok thanks. Will have a look in the morning then and see where I'm at. Will post back on here what I find. Is there anything or any specific way to do any of it that might not seem obvious.
I`ve seen more `04`s crack the cases than other years. That is too much play in the shaft. The shaft should be fairly tight before closing with cover. It can be very hard to get the kick start shaft into place. There is a blind bearing that could need replacing on the other end. A good chance you will need a whole new shaft as this has been updated several times. Take your time and get it right or it can happen again.
Also if you have a riding buddy familiar with this it is worthwhile to get some help. A good friend broke his just as he started a national a few years back. Luckily I had a later start time and the importer had the parts available. 45 minutes later we had new case, gears and shaft replaced. We both finished with plenty of time.
Good luck.
Just about to go pull the clutch basket so will post back what I find, wish me luck.
Idle gear was shafted, pawl gear, kickstarter shaft and the bearing the shaft seats into looked fine, so after a trip to my loacal (and really well stocked) trials shop BVM this morning and an expensive shopping list the bikes back together (wish I hadn't of taken the engine out yesterday though!).
Parts needed:
2011 Clutch Cover
Clutch Cover Gasket
Kick Start Oil Seal
Water Pump O-Ring
Water Pump Seal (Didn't actually need that)
Kick Start Idle Gear
2x Clutch O-Rings
Sight Glass
Total £185 :crying:
Idle gear damage...
I do have two concerns though:
1. There was no trace of any pieces of idle gear anywhere in the clutch cover or clutch basket side of the engine. The teeth do look very rounded and worn though rather than sheared and snapped so I figure i'm unlikely to have found any chunks anyway.
2. The kickstarter still dosen't feel right to me, didn't feel right when I first got the bike a few months ago and i've probably been kicking it wrong to compensate which is probably why the gear went and cracked the case. The kickstarter dosen't feel like its engaging the engine until the kickstart lever is at about the 9 o'clock position, and this dosen't leave enough travel to actually start the engine. This means ive been having to almost start kicking the lever BEFORE my foot is on it! Which I know is a big no no as it can stress the case and idle gear. Obviously If I stall it mid section I can't stop and start rocking the bike about etc, I need to be able to just kick it again and carry on so really want to get to the bottom of this?
Edited by sawtooth
