November 2, 201312 yr Hi there , At one of my local event I recently had a go on another bike with a fat bar conversion and it felt a lot roomier and better than my usual standard cross bar on my beta rev 3. Just wondering what is needed to covert to fat bar ? If so is it any worth it ? I'm looking at either a renthal fat bar or a jitsie fat bar Cheers P
November 2, 201312 yr Hi i converted my Rev 3 by buying some far bar conversion clamps,that bolted to the lower originals,which is cheapest way,but most trials bar are the same width,give or take,or you could try and find a top triple tree of a later model,that has fat bar clamps as standard.
November 3, 201312 yr I put fat bars on a 02 Sherco. Using Pro Taper Suzuki Factory/ KtM bars and adaptors, bar position was almost exactly the same. The extra flex was easier on hands and forearms.
November 3, 201312 yr I've got Fat bars on my trusty old 240 pro , Tag bars and adapter clamps . And I've got a set of S3 adjustable mounts waiting to go on my section , when I get around to it .... I like the roomier feeling and extra body movement I get from good fat bars . And it may be my imagination , but I think I get alot less vibration thru my hands with them too , Make s for a more comfortable ride for me . Glenn
November 3, 201312 yr They do transfer less shock to your hands and forearms. Like when you slam the skid plate on a rock or solid log.......a little less shock is tranferred to your hands. That is the reason I put them on.
November 3, 201312 yr Author Cheers for all your quick replies, i am thinking of purchasing a universal fat bar conversion clamps for around £30, and a set of Renthal fat bars is this all i would need to convert it? It seems worth it for the conversion with lots more room and less flex, Cheers, P
November 3, 201312 yr Here we have a pic of Hebo fat bar adapters on a 4RT. Just bolted straight on. upside: Love my Renthal fat bars for the feel: softer as 'mcman56' said which makes them less tiring, less prone to bending. Also, shortened the bars by 25mm a side to give me that extra clearance between the trees. downside: Looks like it could be a dentist's dream come true as there is no bar pad that will fit. Edited November 3, 201312 yr by ross brown
November 3, 201312 yr I have fat bars on my bike and the absence of a crossbar offers more room for my belly when going over obstacles!
November 4, 201312 yr I've got Fat bars on my trusty old 240 pro , Tag bars and adapter clamps . And I've got a set of S3 adjustable mounts waiting to go on my section , when I get around to it .... I like the roomier feeling and extra body movement I get from good fat bars . And it may be my imagination , but I think I get alot less vibration thru my hands with them too , Make s for a more comfortable ride for me . Glenn My 240 vibrated more with Fatbars,swapped back to protapers,the fatties I had were stock Sherco.
November 5, 201312 yr If you have to add risers to fit the fat bars, it may be necessary to add length to things like wires or hoses. If the grips end up in the same location relative to the bike they may not be needed.
November 5, 201312 yr Author Looking at the renthal fat bars , the width would be near enough the same as my standard renthal bars. Will have to check the rise of the bars due to cable lengths etc... What does the high rise mean in terms of riding position ? I will purchase some adapters from trial uk P
November 5, 201312 yr Well belly up to the bar then. That might be part of my "problem" Buffet Bar.....Beer Bar etc..... and then
November 6, 201312 yr Higher bars will have you standing up straighter when you ride. This can reduce the weight on the front end, reducing front grip a little. Because I am 6 feet tall (185cm) I found that about 1" higher bars was much easier on my back because I didn't need to crouch as much. Also, the grips are 1" closer to my body when going up very steep obstacles. I had to adjust my throttle hand a little to get full throttle.
