trialtrial Posted February 19, 2014 Report Share Posted February 19, 2014 Hey guys, I dont have my TLR200 restoration bike yet, still keeping my eye out (pretty hard to find in Canada). In the mean time, I have been reading and reading the various restoration projects. I plan to modify the steering head angle. I have read a couple of posts and I will insert 6mm in the top tube for a 2 degree angle change. But what about the swing arm? How much do I lengthen it out? Where should I make the cut - will it screw up the shock length? If anyone has any pictures.... thanks! Quote Link to comment Share on other sites More sharing options...
lineaway Posted February 20, 2014 Report Share Posted February 20, 2014 Personally, the front end does need fixed. I would leave the rear alone until you think it has a problem. A shorter turning bike can be much better to ride than what is considered `best`. Quote Link to comment Share on other sites More sharing options...
trialtrial Posted February 20, 2014 Author Report Share Posted February 20, 2014 I have read several complaints about the front end being much too light when the steering head angle is modified. I figure I may as well fix it up while doing the rest of the bike. ... and I found one, so I will be picking it up Friday - yippee! Quote Link to comment Share on other sites More sharing options...
lineaway Posted February 20, 2014 Report Share Posted February 20, 2014 Yeah, would not want it to handle like a modern bike, Huh? Just kidding, I`ve had a few tlr`s and they are disappointing at best. For some reason everyone has a soft spot for the little Honda`s. Quote Link to comment Share on other sites More sharing options...
trialtrial Posted February 20, 2014 Author Report Share Posted February 20, 2014 Interesting point - I will ponder it. And yes, I very much have a soft spot for these pokey little bikes. Quote Link to comment Share on other sites More sharing options...
tlrider Posted February 20, 2014 Report Share Posted February 20, 2014 I recall reading on one of the TLR specialist websites in the UK that they lengthen the swingarm behind the shocks in the axle mounting area. By doing so you keep the original shock location. You are steeping the forks? I have a TLR250 and it appears to be less steep than a Reflex (yours is a Reflex?) from the riders position and I have no steering issues. Subjective opinion of course. Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted February 21, 2014 Report Share Posted February 21, 2014 I see no need to lengthen the swing arm on my TLR200. I did find the bike to be quite top heavy and have lowered the peg mounts (1" down and 1" back) and it helped a lot. I did not steepen the forks because O still use it on the road and did not want it too twitchy. Some people have suggested advancing the cam timing by about 6 degrees to wake up the sleepy motor. I have a new cam sprocket but have not installed it yet so no field report on that. Have fun! Quote Link to comment Share on other sites More sharing options...
andy m Posted February 22, 2014 Report Share Posted February 22, 2014 I see no need to lengthen the swing arm on my TLR200. I did find the bike to be quite top heavy and have lowered the peg mounts (1" down and 1" back) and it helped a lot. I did not steepen the forks because O still use it on the road and did not want it too twitchy. Some people have suggested advancing the cam timing by about 6 degrees to wake up the sleepy motor. I have a new cam sprocket but have not installed it yet so no field report on that. Have fun! Hi, where did you find the cam sprocket?? thanks Quote Link to comment Share on other sites More sharing options...
brewtus Posted February 23, 2014 Report Share Posted February 23, 2014 Hi, where did you find the cam sprocket?? thanks I can't really remember where exactly I bought mine, but Dennis Kirk has 'em in stock - https://www.denniskirk.com/51218.sku?utm_source=google&utm_medium=cse&gclid=COj54-et4rwCFYtDMgod_XsAvQ It really woke up my 'Flux. LOTS more bottom-end oomph for $20 and about 45 minutes work. Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted February 23, 2014 Report Share Posted February 23, 2014 Hi, where did you find the cam sprocket?? thanks I got mine on eBay. Predrilled for the advance. Quote Link to comment Share on other sites More sharing options...
4stroke Posted February 23, 2014 Report Share Posted February 23, 2014 I agree with other posts, try before you extend. Mine works fine with head angle mod and standard swinging arm length. Quote Link to comment Share on other sites More sharing options...
stpauls Posted 2 hours ago Report Share Posted 2 hours ago One reason to extend the swinging arm by 1.5 " - 2.00" inches is to keep the front end on the ground when accelerating uphill. Quote Link to comment Share on other sites More sharing options...
