August 24, 201412 yr would like to see some video if possible, thanks for the update. Sorry I didn't see him on time to film it, but will post it here if I find some footage on youtube
August 24, 201412 yr here he is practicing http://youtu.be/yFGqemeYCYI Edited August 24, 201412 yr by borus
August 27, 201412 yr Author I found this snippet in the manual, which certainly sounds to me as if the clutch operates as a potentiometer of sorts, rather than just an on/off switch: The ELS system allows you : - To cut instantly the power of the motorcycle. - To modulate progressively the acceleration of the motorcycle. - With the combined effect of the throttle and the ELS lever, to have a very precise action of throttle, usefull in very slow and winding sections. The effect can be compare to a mechanical cluch. - Like a thermical engine cluch, to have instantly the full power when needed.
August 27, 201412 yr That type of clutch was on the very early bikes, since last year the clutch is on / off. A gradual clutch is no different than the throttle on an electric bike. cheers
August 27, 201412 yr A gradual clutch is no different than the throttle on an electric bike. cheers this will very much depends on the type of controller and also how the clutch integrates with the controller .. So not the same for all electric bikes.
October 8, 201412 yr First full size electric to win at nation level: http://news.motorbiker.org/blogs.nsf/dx/a-first-electric-motorcycle-wins-national-championship.htm But not the all round first e-trials to win at nation level.. Edited October 16, 201412 yr by gwhy
December 4, 201411 yr Here in Australia we have a former Australian Champion riding one and he’s pretty darn impressive on it. He rides expert class on it and eats all but the biggest sections. He was kind enough to give me a test ride on it last weekend. I was quite impressed with the power but the bike takes some getting used to. As stated above, the clutch is just an on-off switch and best left alone. The regen braking is applied using a button on the left handle bar. Normally there is very little engine braking. Power delivery is smooth but you can’t get that instant zap that you can get with a petrol engine and a clutch. You need to use your body to get up the big stuff (but riding a 300 Gasser makes one lazy so I can’t do it). I must say the power is a lot smoother and more controllable than the little Oset electric bikes. As for endurance, the owner rides an all day trial (4 laps of 10 sections) and then does a few demos afterwards with about 15-20% power remaining so I think the advertised times are pretty conservative. Chris Brisbane Australia.
