August 17, 201412 yr Does anyone know if an ajp front kaliper will work with a formula master cylinder ?
August 17, 201412 yr Yes, it will work, you might loose or gain a little braking power depending on the piston diameters but I think they are about the same. I've done the other thing, use a AJP master cylinder (from a 4RT) instead of the Formula on my 2012 GasGas, and it worked just fine.
August 17, 201412 yr I can agree with guys, I also swapped the Formula (clutch master cylinder) for AJP.
