Knockin' Not Rockin'
nordy
Hi All , need abit of help, 2011 sherco 290 started to knock for no reason replaced main , big end bearings con rod small end and pin, piston and barrel where perfect, but engine still knocking, puzzled, any ideas would be great. Thanks
Thanks for the reply, checked flywheel nut, stator, clutch, every nut and bolt tight, even put the piston and barrel from a 2013 bike on , no joy still knockin, Its astrange one.
Well, from what you have stated it is not the top end, the bottom end or the gears, so it must be fine!
Let us see and hear a vid ofit! It is difficult to diagnose noises or the tinternet. My crystal ball sucks!
You state replacing big end bearing? Possibly so, however last time I checked, thece come in a conrod kit with a new rod and crankpin. You know, the other mating wear parts there upon a true lower end knock. What is your clearance Clarence?
There are only so many rotating parts there, you know!
Thanks Copemech, Naichuff,Melba26, Heffergm, Dadof2 and last but not least Thats a five for all of your input , Melba26 you where close , it turned out to be the clutch rubbers, never thought they would cause such a knocking noise, lesson learned, thanks again for your help.
