Quick Or Slow Action Throttle On A 200?
The gearing worked out well at 11/44, second and third gear are nice for hill climbs.
I'll leave the throttle as a slow throttle for now, I spend enough time crashing and loosing grip as it is. Although the thought of trying a fast one out is still nagging at me! Thanks guys :)
Edited by hrmad
  • Replies 47
  • Views 26k
Most Popular Posts
  • I had the same issue on my 200. I left the gearing as standard but fitted a quick action throttle and it transformed the bike.
  • If you go for a fast action throttle and don't get on with it but don't want to go back to the slow action then modify the fast action to a "medium" action... (see below) Put 2 hacksaw blades togethe
  • betabonkers
    betabonkers
    Don't need a cable, just get a white tube.
I can't use a slow action, fast all the way
Don't tempt me, haha!
Heather 11/44 is pretty much the same ratio as 10/41, going to a 9 is way to low though.
I think you can just buy the tube for the throttle, no need to buy the whole assembly.
I know, I've gone full circle back to where I was at the start. 10/44 was too slow so I just put the 11 back on, rather than remove the rear sprocket. I suppose at least i've got a spare set of 10/41 when the current set wears down or I sell the bike.
I'd need a new throttle cable too?
Don't think so, just the tube, about a tenner
Edited by the addict
It would be more comfortable in hill climbs to use less wrist movement, or getting up short steep banks... I suppose it's cheap enough to try out.
I've gone and bought one, mind changes direction like the wind! When it's fitted I'll post how I get on, thanks
on my trusty old 240 pro I use a slow tube , as my bike the way it is ported , responds like a MX bike . On my Section I have a quick tube , as it has much more and smother power all over . And mind you both bikes are geared way low , I very rarely use first gear ... and both will chuggle along at serious low revs ... but it all gets down to what your comfortable with !
Glenn
Thanks Glenn.
Fitted the quick action throttle this morning. Had a go on it going slow and it's fine, better in some ways cause I didn't stall the engine as much as I usually do- easier to keep revs up if that makes sense.
The real acid test will be going up hills, I'm going to a practice day on Saturday so should give it a full work out. Feels better so far :)
Just trying to get some new grips on now, like trying to wash a cat!
Edited by hrmad
went to a local training day today. Throttle was fine, no complaints. None of my crashes involved using too much throttle, haha.
I was told my bike is too fast again, and to go to a 9/52. I kept stalling in first gear all the time, she'd even stall with the clutch all the way in?
