My Bike Only Starts With Throttle Wide Open
I have a 2008 rev 3 125, carb is clean and it ticks over once started but it only starts with full throttle. How do I sort this?
Edited by itstommmm
Maybe a bit rich or air filter clogged over oiled what's plug colour
Plug colour is like the color of wood, should I try to start without air filter in? I think I've over oiled the air filter.
Dry it off then with some kitchen roll only needs a very light covering but make sure its covered all over.
Do a search on the net loads of how to vids :)
have gave air filter a clean with hot soapy water just like and will re oil it once dry.
There are many reasons that this could happen. Too much fuel, not enough air, wet or clogged exhaust packing, low compression. No matter what the found reason is, you have to oil an air filter.
It proves that if you put too much oil on you can choke the pores I suppose but filters are not oiled to keep out water, rather to catch dust, which we do occasionally get in the UK. Internal surfaces of air boxes (both sides of the filter) coated with grease for a similar reason.
well i have never oiled a filter. you dont need to oil one on a trials bike if your in the uk,
Your call, it is your bike
But the foam IS NOT the filter
All it does is hold the filter oil in suspension
The oil IS the filter
So you may as well not run a filter at all if its not oiled
