Txt 270 Or 280?
Don't seem to be able to get 5w 30 anywhere. I have some 10w 40 at home, so it's either that or the ATF.
At least the brake fluid was straight forward. lol
  • Replies 64
  • Views 17.3k
Most Popular Posts
  • I am beginning to think that myself. The 280 is only 3 miles away and the 270, 40 miles, but both will go in the back of the Discovery. Would the 280 not  have been sorted in its 13 years history by n
  • crazybond700
    crazybond700
    Some older engines dont have the filler hole for some reason.   http://thumbs1.ebaystatic.com/d/l250/m/mgrNcO9iQBiPujA1kmDWg8Q.jpg   Yours has so just smile and fill her up!
  • crazybond700
    crazybond700
    Yes its the one behind the kickstarter
I have good results with 10w40, atleast no real problems (in several pre-pro models). But thinner could prefent sticking problems e.g. better.
If you do get problems you can just swap again, its not damaging the clutch or something.
Edited by crazybond700
I think that's the plan. Empty out the ATF which may be old anyway, then try the 10w 40 which I have some of anyway. Well at least until I can find the 5w 30.
Well a local rider came over and declared my bike to be a good example, with only a few minor check to do. The chain needs tightening a little and I just need to check the coolant level. I assume this is just a case of lifting the fuel tank. I may drain at some point. Otherwise he says it rides well and doesn't;t appear to have had a hard life, which is good to know. :D
