January 14, 200422 yr As an observer at a recent trial I had an unusual situation come up and I would like some opinion on how you would score this. A master rider launched over an obstacle to exit the section; his front axle was out of the section when he stopped and put a foot down outside the section, but his back tire broke the red tape because of where the bike landed. He had cleaned the section so I scored him a zero - should it have been a five?
January 14, 200422 yr I'd would have called it a "0" like you. Once the front axle is out, the ride is over...or at least that's what I always thought.
January 14, 200422 yr Anything that happens to the section after the front axle is out has nothing to do with the score for the ride. I would have given the clean.
January 14, 200422 yr i was told years ago that the front wheel starts and finish's the section, so on that basis i would have given the rider a clean. Gaff. Edited January 14, 200422 yr by Gaff
January 14, 200422 yr Clean........................ read the rules! The front axle governs the start and finish in a section. Dave
January 14, 200422 yr If the front axle was out of the section before the tape broke then it's a clean. If the tape broke at the exact same moment the front axle crossed the end gate (on or off the ground) it's an unfair five
January 14, 200422 yr I would have given the rider clean, but only after he had tied red tape as it was...
January 15, 200422 yr That would be clean by all the different sets of rules I've ever ridden under. Front axel had broken the plane of the end gate before the rest happened.
