lineaway Posted January 19, 2016 Share Posted January 19, 2016 It looks like a `96 to me. Get a new plug. Is the plug wet or dry. If it`s wet it could be flooded. If it`s dry, I would pour a few ounces of mixed fuel down the plug hole and try to start. Gassers very rarely sheared the key, but if all else fails pull the nag off. Quote Link to comment Share on other sites More sharing options...
sr1murray Posted January 19, 2016 Author Share Posted January 19, 2016 According to the registration document it was registered in June 1996. I'll do some investigation on it and see if it's the right engine/frame etc. Thanks again everyone. Much appreciated. Quote Link to comment Share on other sites More sharing options...
birdy Posted January 19, 2016 Share Posted January 19, 2016 Was the bike bought as a non runner? Try all the above first but if still no joy do a compression test with a compression tester, I had same problem, it felt like loads of compression on kicking over but tested with meter and not enough, stripped and piston rings stuck on one side as partially siezed. Cleaned up ring grooves on piston and 4 years later still going strong, good luck. Quote Link to comment Share on other sites More sharing options...
h59elmer Posted January 19, 2016 Share Posted January 19, 2016 All of the above possible. One hard rule to remember for 2 stokes is three elements needed to get one to fire. Compression, Spark, and Fuel one of the above is missing. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted January 20, 2016 Share Posted January 20, 2016 (edited) Always start with a new plug. Try again. If the plug comes out very wet, undo the plug, make sure the plug wire is not near the cilinder, and put it in gear and walk. (with the tank off and carb let of). Those bikes will always start, we got a lot of those, and only problems somethimes are the plugs! Great bikes and all parts still available. Edited January 20, 2016 by crazybond700 Quote Link to comment Share on other sites More sharing options...
sr1murray Posted January 20, 2016 Author Share Posted January 20, 2016 Thanks again folks. Your responses are greatly appreciated. I've not got a great deal of time today to devote to the bike, but should be able to give it a good few hours tomorrow (Thursday) so I'll let you know how I get on! I've gone out and got some new fuel (super unleaded) and new oil. I'll pick up a new plug and go from there. Once again, I can't thank you all enough. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted January 20, 2016 Share Posted January 20, 2016 Also while your at it, check the airfilter. Quote Link to comment Share on other sites More sharing options...
reggie Posted January 20, 2016 Share Posted January 20, 2016 No new news ? Quote Link to comment Share on other sites More sharing options...
sr1murray Posted January 20, 2016 Author Share Posted January 20, 2016 I'm afraid not, Reggie. Busy day with not much time to spend on the bike. Should be able to give it a few hours tomorrow. I'll update you all tomorrow night! Thanks all. Quote Link to comment Share on other sites More sharing options...
collyolly Posted January 21, 2016 Share Posted January 21, 2016 I think GasGas UK had a problem with 'grey' imports back in the 90's and had a batch of bikes produced in Grey to try to isolate the problem, you used to get asked about your bike before spares were sold to you ( anyone else remember when that was ?) Either that or someone has just fitted a set of plastics from a 320 , I had one in silver I think it was a 98 ? Quote Link to comment Share on other sites More sharing options...
