February 12, 201610 yr Hi, has anybody out there had any experience with this type of clutch actuator ? Does it make a big difference or none at all to the lightness of the clutch ?
February 12, 201610 yr Author Here, http://www.swm-moto.net/en/?jjj=1455288193313 Used to be here, http://www.swm-moto.org/ Registro storico SWM It's quite a long winded process, you get shown a list of parts, you tell them what you want, they check the availability and quote you a price, you pay, they send. The guy I dealt with was one Mauro Sironi, a relative of the SWM founder Piero ?
February 12, 201610 yr Author FYI, the arm, spring, retaining plate and ball bearings are all Aprilia parts, it just the round plate at the back which sits on the original ramp tops (this is not true, check out the Barnett clutches thread for the documented pictures) in the casing which has been specially made. It also has ramps cast into it for the three large ball bearings. AP0259325 that's the part number for the arm b.t.w. Yes indeed, the site is full of interesting stuff, glad you like it, hope you find what you're looking for too. Tschau, Phil Edited March 10, 201610 yr by brownie001
March 9, 201610 yr A friend is working on my Rotax powered Can-Am 240 trials bike and discovered this gem today!!! Looks like a custom job to smooth out the clutch just a bit. I've yet to even see OR ride this bike yet, so excited to try it out. All feedback is welcome!
March 9, 201610 yr Author Now that's interesting. The arm you have is made of steel and has been lengthened by probably 10 mm. That was a well known mod on the original actuator arms. The one I have, which is an Aprilia part, is diecast ally, so a little more difficult to extend if required. There certainly are more than one way to skin a cat !
August 27, 20188 yr Thanks Brownie001 for the Aprillia Part number... Heres a link to the parts page, showing the rest of the part in the Lever assy. https://www.bike-parts-aprilia.com/aprilia-motorcycle/125-APRILIA-MOTORCYCLES/CLASSIC/1996/ENGINE/Clutch-cover/122/2/444004862/18 Found one a few on ebay.... so looks like a conversion is coming up !.
August 28, 20188 yr Author Hi basinbaker2, if you are going for the conversion but keeping the original SWM casing, the ramps need to be milled off and a special plate with cast in ramps is required. When I finally got hold of mine from Italy, I had a few cast if you are interested. In fact, just checked, I have all the bits for two complete conversions plus 3 more cast plates and various adjuster screws and 12 mm balls. PM me if you are interested. Phil
October 6, 20188 yr On 9/1/2018 at 11:13 AM, brownie001 said: Here are the parts required. How much are you wanting for the complete kit? Is it just a direct replacement for the stock one BTW?
October 6, 20188 yr I’m interested too! Can the parts be bought as a kit or ordered piece by piece? How much involved is it to have the old cover milled? I don’t think I would attempt it on my own with my mill.
October 6, 20188 yr Author Hi, except the cast plate, bottom right, everything is an Aprilia part or a simple third party for screws, spring and so. Check the Barnett Clutches thread for more details. The milling involved is not too big a number if you have experience with your machine, should be no problem. I have four plates left. That includes one complete set as in the pic. I'm asking €20 plus p&p for the plate alone and €60 plus P&P for the one complete set. As you are in the US, you might like to keep an eye out for later Can Am Bombardier engines which are being broken. They have the same setup but with a steel arm which you can cut, extend and weld. The best fix for a better, lighter mechanical clutch is to get hold of an Aprilia TX cover or an air cooled climber one. Hens teeth here. If your Italian is 'Intuative', as indeed mine is, you can also get everything you need here, http://www.swm-moto.net/en/?jjj=1455288193313&jjj=1459258046796 Phil
