New 4Rt Owner
just picked my new 4rt up this is going to be a steep reintroduction to trials
My first 'proper' ride on the new 4RT at Exmoor M.C. tomorrow; after having run in last weekend....
Suspension set up, 9T front, 46T rear, X-lite front, IRC rear, oils and filters changed......
Can't wait to make some noise........
9/46? you might want to check if the trial has a finish time. Best of luck though, that gearing is incredibly low if correct?
If you've got Morad rims then that IRC might come off.
Edited by the addict
9/46...... it's all about personal preference isn't it?......
IRC's, been running them for years at down to 2.5lbs when required, never had a problem on any rim. 'Duck tape' modification is all that is required....
Yes it is I suppose but that is incredibly low. I couldn't keep an IRC on my rims no matter what I tried.
I am a bit eccentric and run stock... But if I was going to lower it I wouldn't go lower than 9/43... My 2 cents for what it's worth.
I pick mine up next week, the "300".  I'm wondering about the re-intro curve, though I was not advanced when I stopped 5 years ago.  I figured the Montesa would be an easy to live with step back in, with ease of starting, quieter (neighbors, and houses near riding areas), etc,
A few weeks of riding, I'll have a good idea.  Hopefully the experiment / expensive risk will turn out positive.
