March 12, 201610 yr Hi all, Just got myself a lovely little fantic 200 (rear kick). It is very original and I'm considering moving the footpegs. Can anyone recommend an engineer/fabricator/welder, preferably in the southwest of England to carry out said work? For you guys and girls that have tried these great little bike with both original and relocated pegs, how do you find the difference? Is it an essential mod? Thanks in advance for any advice and opinions tjp
March 13, 201610 yr The biggest improvement is the wider footrests that get fitted, I did move mine back and down a little bit (approx 15mm down 20mm back) but I'm 6'5 so wanted to stand more upright on it. Don't get talked into steering angle mods this not needed on the 200 minarreli, but check the webbing that connects the top tube to the down tube under the tank, it may be cracked, easy weld job if it is.
March 13, 201610 yr As furse says, i dont think it needs a headstock change but yes yes do look at the footrests. If you wanna keep the same position do so but i lower and move about 3 and 3 cm. Most important, and my reason for getting a grinder out..the footrest mounts if standard will more than likely be cracked...unless its been in a museum. Maybe the cracks are only visible if you sand blast the bracklets but I would not wanna take the rist with standard bracklets unchecked
March 13, 201610 yr The biggest improvement is the wider footrests that get fitted,What's the advantage of the wider footrests? I've seen these mentioned a lot but have never ridden a bike with them.
March 13, 201610 yr A larger platform for your feet to plant on is just so much more comfortable and controllable ,
March 14, 201610 yr Tjp, best thing I could recommend is have a look at yellow pages find a few companies locally and just give them a call, go see them and see who gives you a warm feeling! Thanks axulsuv, I guessed it would be something like that. Might have to try some in my bike.
March 14, 201610 yr Ypu don't want a warm feeling in the ignition. Electronic systems have been known to suffer with electric welding. Take care.
March 16, 201610 yr When electric welding you must first disconnect the coil wires, plug top as well as battery terminals this applies to any vehicle bike, car, tractor or truck both petrol and diesel. Footrests with a bigger platform area are definitely the way forward, you only have four points of contact between you and bike so good footrests and bar grips are essential. Edited March 17, 201610 yr by trialsrfun
March 18, 201610 yr If your doing the job...do it proper! strip the bike and get it shot blasted,then weld your extensions on and then get it coated.Full factory
