October 25, 200521 yr hi i would like some help as i have just bought an 06 gasser 250 and sometimes when warm it takes a few kicks to start it any foughts would help cheers
October 26, 200521 yr Yes, mine does the same. I found if you kick it over without using the throttle, if usually starts but if it doesn't fire then it takes a few kicks for it to go.It must be the pilot jet or something to do with the carb.Anyone know what Munch did to retify?
October 26, 200521 yr Try this post from earlier in the year it may have some relavence to your problem.Starting
October 26, 200521 yr Have you done this ? Check out the Gas Gas Uk site GGUK about 3/4 topics down in the news IMPORTANT 06 PRO JETTING INFORMATION (thats what its called).
October 26, 200521 yr As it says on the Gas Gas UK website, The jetting should have been sorted before the bike left the dealer and if it wasn't i believe Shirty would like to know!!!
October 28, 200521 yr Oooooooooooooo I love to be right! <{POST_SNAPBACK}> You're well up on your Gasser knowledge Dabster, anything to tell everybody?
