lotus54 Posted May 27, 2016 Share Posted May 27, 2016 (edited) I've made a new addition to my OSSA (2104 Explorer) The AAA Rechargeable batt (inside the factory Easystart) gave me some issues on a ride, so I hooked up LiPo battery and it worked great. But I didn't want to leave it in all the time, so I installed a KTM style start button. Wired it so the LiPo battery could apply power to the Diagnostics port. This runs the fuel pump for a moment and 'wakes up' the ECU. The bike starts first kick cold or hot. The LiPo battery is quite small. I'll get some pics etc. working on getting more connectors, but just used the 'dummy' plug with some appropriate pins. Mark Edited May 27, 2016 by lotus54 4 Quote Link to comment Share on other sites More sharing options...
canada280i Posted May 27, 2016 Share Posted May 27, 2016 Get them pics and the battery specs up mark!........intrigued..... Quote Link to comment Share on other sites More sharing options...
volcano island trial Posted May 27, 2016 Share Posted May 27, 2016 Is this 12 V power LiPo battery which you connected to the diagnostic connector ? Quote Link to comment Share on other sites More sharing options...
lotus54 Posted May 27, 2016 Author Share Posted May 27, 2016 (edited) Yes, 3 cell LiPo http://www.amazon.com/Turnigy-1300mAh-20C-Lipo-Pack/dp/B0072AEKY8?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00 And starter button http://www.amazon.com/Technologies-12-0215-Style-Electric-Switch/dp/B007GLUJRU?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00 I'll make up a wiring diagram, but super easy. I put the battery under the seat, but certainly could be up by the handlebars or something I left the factory Easystart etc. installed. This is in addition. Also would,be useful on huge trail if you had some issue, hit the button and can tell if the fuel pump is running. Edited May 27, 2016 by lotus54 Quote Link to comment Share on other sites More sharing options...
canada280i Posted May 27, 2016 Share Posted May 27, 2016 did you also need a charger for the lipo? Quote Link to comment Share on other sites More sharing options...
lotus54 Posted May 27, 2016 Author Share Posted May 27, 2016 Yes, I do,have a charger, it is a balance charger and not very much. The battery should not require charging very oten. Quote Link to comment Share on other sites More sharing options...
badger360 Posted May 27, 2016 Share Posted May 27, 2016 Only problem is lipos can explode or swell up if the battery is drained below a certain voltage l raced modle cars for years using lipos and they must be balance charge and in a fire proof bag .the battery must never be aloud to go flat,modle cars have a low voltage cut off to prevent the battery from being damaged or worst catching fire ,they produce much more power than a normal battery Quote Link to comment Share on other sites More sharing options...
lotus54 Posted May 27, 2016 Author Share Posted May 27, 2016 In this case it is only used a few seconds at a time. But I take your point and will make allowances Quote Link to comment Share on other sites More sharing options...
badger360 Posted May 27, 2016 Share Posted May 27, 2016 Just keep an eye on the lipo if it swells bin it,you can buy the same battery in a protective case they are more money but does stop the battery being damaged if a cell is puntured it will start to smoke and catch fire.hope it all goes well keep us posted Quote Link to comment Share on other sites More sharing options...
volcano island trial Posted May 29, 2016 Share Posted May 29, 2016 Could you send us picture as everything installed on your bike ? Quote Link to comment Share on other sites More sharing options...
canada280i Posted May 29, 2016 Share Posted May 29, 2016 Everyone is very eager mark, you may have found the holy grail.....! Quote Link to comment Share on other sites More sharing options...
lotus54 Posted May 29, 2016 Author Share Posted May 29, 2016 Rode all day yesterday and a bit the day before. The 'button' works great and super easy starting. Bike is covered in mud right now, I'll try to get it cleaned up and take some pics. I did manage to loose the left side plastic piece, the one that says 'OSSA' on it and is bolted on, not the cliped on one. Darn it! Probably can't get one either. If anyone knows of a source, please let me know. Quote Link to comment Share on other sites More sharing options...
peterb Posted May 30, 2016 Share Posted May 30, 2016 Hi lotus, I might have a spare here if you get stuck. Can you make some space in your messenger inbox, unable to send you a PM. Bye, Peter B. Quote Link to comment Share on other sites More sharing options...
lotus54 Posted May 30, 2016 Author Share Posted May 30, 2016 Hi lotus, I might have a spare here if you get stuck. Can you make some space in your messenger inbox, unable to send you a PM. Bye, Peter B. I cleaned up my PM box. Thanks! Quote Link to comment Share on other sites More sharing options...
canada280i Posted June 8, 2016 Share Posted June 8, 2016 don't forget pics of the installed east start mark when you get a moment Quote Link to comment Share on other sites More sharing options...
