August 5, 201610 yr I have done a great job damaging a fork stantion on my 2012 gas gas txt pro . A second hand pair of forks has come up for not much more the replacing the one tube, they are off a 2009 txt pro . Question is are they the same fork ? No changes between years ? Cheers Will. Edited August 5, 201610 yr by will_d
August 5, 201610 yr How badly damaged is your fork tube? I repaired a scratch on my 2011 using nail varnish then smoothed it off with 1200 grit wet & dry, I then replaced the seals with best quality green SKF seals and never had any leaks. Could be worth a try. Edited August 6, 201610 yr by topline620
August 5, 201610 yr If they are the stepped down style the part numbers are the same! Edited August 5, 201610 yr by jfc
