Flywheel Weight ?
anyone of you good Fellowes fitted a flywheel weight to a  250 trs , can you fit one ?? had a peek behind my cover and it looks a bit special in there
cheers
andy
i think it may do to suit my sh*t riding style !  i have a slow throttle which helps but just a little more help would be good.
its probably not going to happen as the flywheel is an inverted type , so is not easy to bolt one on !
I think the TRS has a "crankshaft" bearing in the flywheel case. This may make fitting a weight a bit trickier than usual.
Lower compression? Smaller bore carb? Reduce the diameter of the exhaust either at the engine or tailpipe using an insert?
  • 4 months later...
  • 1 year later...
The vertigo has essentially the same "design" at least at the flywheel, and someone makes a light and heavy flywheel weight for those bikes.  Maybe soon they will make them for the TRS or something.
  • 4 months later...
