Fantic 305 noise
No, a friend of mine who builds mostly large drag racing engines did it for me.I'll find out what company supply the stuff,probably an American company.
  • Replies 47
  • Views 17.8k
Most Popular Posts
  • ask greeves
    ask greeves
    Fantic Tom, Would have been nice to have seen the markings (letters) on top  of the barrel and the markings on top of the piston (in your photos), these should correspond (be the same). Next, if the b
  • pschrauber
    pschrauber
    Again I would leave everything as it is reassemble and in the meantime save some money for a complete rebuild of cylinder, custom made piston and con-rod with new upper and lower pins bearings and if
  • Pistons can also be sprayed with a bake on coating,this is a low friction surface which can be 1/2 a thou thick,so up to a thou on O/D. Works very well,my AJS is is running with it,I also had a pair o
10 hours ago, fantic tom said:
Looks good did you do this yourself?
Hi Tom, Had a good look at both an old used piston and a new piston, seems taper on new piston (difference between top and bottom) to be 8 thou. Whereas the old used piston. the difference is 16 thou. I also had an interesting conversation last night with the guy who had re-engineered his piston. The long and short of it.....He made a 3/8th thick dural/alumium disc, after heating piston for 20mins in oven at 200c, took measurement (while hot) at the piston inside register and made a size fit disc (fitted cold to the hot piston) cooked again at 200c for 30mins then left in oven overnight (to cool slow).  I suppose you could have a measure up, to see how much your own piston has worn/distorted, and may help in getting a fuller idea as to the sort of clearances involved.
