Montesa/Honda 348 ?
Its def a 349 prob an 81yr model, released as celebration of their 1980 world championship. As already mentioned pretty much all of the bits are available for them but the motors are a law unto themselves.
  • Replies 34
  • Views 7.8k
Most Popular Posts
  • montesamadness
    montesamadness
    Hi Netley In answer to your original question, most parts are readily available from the likes of InMotion trials in Surrey and others, and parts regularly surface on ebay. However.....
  • collyolly
    collyolly
    348 was a Montesa before Honda were involved, later 349's were when Honda got involved if I remember correctly. Get some more information or a photo of the parts for a better idea as to its age.
  • cleanorbust
    cleanorbust
    That's not possible if it is indeed a 348. The 348 was replaced by the 349 in the Montesa line-up before Honda bought them out.
Yes I'm definately interested as long as the engine is ok as it seems they aren't exactly straightforward to rebuild.
I've never really got on with left foot braking on my Bultaco being used to Japanese road bikes. I may prefer it but can't keep both.
If I get it I will probably be bombarding the site with questions.
thanks for all your input.
Neil
Well, it does say 349 on the side plastic.   B)
Have fun with it if you get it.  :thumbup:
Cheers people. I'm picking it up a week Friday :)
Hi, I picked the Montesa up yesterday and I have a few questions. The frame/engine no. is 51M22445 there are definately not any lower frame rails. After a cursory glance it looks like the bash plate is just hooked on at the back of the engine and doesn't give any rigidity.
Also, are the forks standard, is the fuel tank road legal, it looks like fibreglass, and is the carb original ?
pics to follow.
More pics to follow.
Carby and forks and frame look right for a 1981 349. Front wheel having a gold rim means it is from a later bike. I'll have another look at it
Front wheel looks like a later model Montesa Cota that has a Honda hub (from after Honda bought part ownership of Montesa~1985 maybe)
Here's hoping the Honda hub is an improvement ;)
The bashplate is not the original one and doesn't fit very well.
I wouldn't worry much that it is not working as a stressed member with those rear mounting clips like that.
The motor castings are easily strong enough to act as the frame member as long as the engine mount bolts are kept tensioned and you are not planning to ride at world trials championship level or race it over the jumps on a modern MX track.
I'm a complete beginer so there's no danger of that.
Will the plastic tank ( repaired with fiberglass) be road legal ?
Keep the spokes tensioned nicely with that hub because they are known to crack around the spoke flange if the spokes are not kept tensioned properly. I'm not sure if it is the Honda hub from that photo, but the later model Montesas had them and it looks like one from what you can see.
UK Montsas usually have an aluminium tank inside a fibreglass cover. I'm sure you could get one of the aluminium tanks and use your tank to make the cover from. Sorry I don't know the road-legal status of fibreglass tanks in the UK in 2017
