New bike, nae grip ?
6 hours ago, billyt said:
Dae ye noo.
Without the aid of Google what is this then?
Twabridiesaplenaneananinginaneana"
Fer Forfar? Bat et'sgeetfeckalltadowigrip.
Edited by shyted
  • Replies 31
  • Views 8.6k
Most Popular Posts
  • Setting up your suspension. Find out the static sag as your stating point. That's where the suspension supports the bikes weight and gives it it's riding attitude. Some where you will find t
  • elusivemite
    elusivemite
    Get the sus setup and ride it bud. In as much mud as you can find.   Don't try and ride it like your Gasser need to learn its quirks.
  • sirdabalot
    sirdabalot
    I too have been riding bikes for centuries and have been able to sus out that I can't.
Cabby, you could also trying to give Splat shop a call and find out what the sag the should be ,or standard spring length when fitted and have a chat with them. I have searched for the adjustments and can't find them, although I haven't tried the Shirco web site, I looked at Splat shops and they sell springs, do overhaul and their web site tells you how to and what tools you need to change a spring. I say this because they could possibly have some advice to give you if all else fails .
I ordered a heavier spring from them the other day, it's fairly easy to change the spring. Got myself a flywheel weight as well though not sure about that, well particularly the how to fit it as I don't have an impact gun to pop the retaining nut off.
I have nae idea what you are talking about but at a guess, the standard spring will be probably for a 70kg rider, I'm near 100, so again guessing, there must be a reason why they produce heavier springs, surely it can't be a sales gimmick can it ?
ive had both, i do think the sherco grips well enough but found you need to get your weight further back on the bike than the gg.
On 3/26/2017 at 7:49 PM, billyt said:
Maheidsfernippingwaeyonwan. puntersdiinnikenaboutyonclabberootinthehelands.    Gonyerself.
I'm glad you guys understand this. Thought I was having a stroke!
My head is sore from all these guys not knowing about the mud in the Scottish highlands.  On you go and figure it out.
Simple..........   Now..........  aweinbileyerheidyabunchotuchters
