Beta Not Running Right
Help my beta is not runnig right :D
Its not crisp at the top end and splutters and on the odd occasion spits a flame out the exhaust.
any idea on whats wrong?
James
  • Replies 40
  • Views 10.6k
could it be the stator and how much will that cost to replace its an 02 rev3 250. :D
anyone got a flywheel puller i could borrow or know where i can get 1.
James
I wouldn't have thought it was the stator going James, I've heard they either work or they don't work.....take the carb off and clean it out, change the plug and the plug cap before you go pulling the flywheel off.
Pullers are not much money from your local dealer (under
local dealer is sammy miller
and hes a tight *** so he wont stock 1
i will give the carb a clean i have tried a differnt plug and the carb was cleaned before i took it out(this is the first time i took it out) i have only had the bike for about 5 weeks.
but i will double check by giving the carb another clean
James
but why is it throwing flames out the exhaust on the odd occasion at high revs
My friends gasser did that but it was completly fegged, sure you cant remember putting on that flame kit that was posted on forum a few months back ? :D
its bloddy annoying hopely will solve it.
it really annoys you and make u wanna sell the bike :D
if its still like it after ive clean the carb again etc etc
ill have to pull the flywheel :D
does anyone know the standard carb settings for an 02 rev3 so i can check all that.
would anyone be kind enough to lend me a puller to see if the key has sheared :P
James
it runs fine up to about a third of the throttle and thn at high revs like misses and doesnt rev cleanly
James
Lots of knowlegable advice here already but I'll echo r2w's suggestion of a broken flywheel (woodruff) key. Unless the carb is completely gooped it's unlikely to cause a severe misfire. Could be electrical (check all wiring for breaks/shorts etc. and swap the plug) but check the key first 'cos it's easy.
wouldnt the flywheel key also stop it running properly at teh bottom end tho?
because it runs fine until about half throttle.
James
