September 17, 20178 yr A little help please. I have a gas gas 300 txt pro 07. As I was told. Can any 1 confirm this off the num. Vtrgg3002f0740086 Also can any 1 tell me how much oil for a oil change. Thank you all very much. Edited September 17, 20178 yr by stilly36
September 17, 20178 yr I downloaded the manual for my txt pro from here mybikemanuals.com Told me how much oil, maybe give info on Id ?
September 17, 20178 yr Id say looking at the tank sticker and airbox its either an 04 or an 05 model , 400ml gearbox oil , no more or it will spit it out of the breather pipe
September 17, 20178 yr Sorry didnt look at the airbox stickers properly , going on the tank sticker and the plastics by the headstock its a 2005
September 17, 20178 yr 550cc from empty but use your sight glass until it's half way up.2007 had a black frame. 2004 and newer (after July 2003) Example: VTRGG 3002 D093 9955 VTR = International manufacturers code. VTR = GasGas GG =Trial model (Company code to identify model EC = Enduro & MX, FS = Four Stroke, WD = Quads) 3002: 30 = 300 model. 02 = (02 = year of Europe homogulation N/A USA) D093: D = 2003 ALPHA CODE FOR MODEL YEAR. 09 = Manufacture month (9TH month) September. 3 = Year of manufacture 2003. 9955 = sequential chassis number. (9,955th built in this year.) “Alpha” model year codes Model engine size codes D = 2003 J = 2008 12 = 125cc E = 2004 K = 2009 20 = 200 model (175cc) F = 2005 L = 2010 25 = 250cc G = 2006 M = 2011 28 = 280 model (272cc) H = 2007 N = 2012 30 = 300cc Edited September 17, 20178 yr by bilks
September 18, 20178 yr Author 10 hours ago, bilks said: 550cc from empty but use your sight glass until it's half way up.2007 had a black frame. 2004 and newer (after July 2003) Example: VTRGG 3002 D093 9955 VTR = International manufacturers code. VTR = GasGas GG =Trial model (Company code to identify model EC = Enduro & MX, FS = Four Stroke, WD = Quads) 3002: 30 = 300 model. 02 = (02 = year of Europe homogulation N/A USA) D093: D = 2003 ALPHA CODE FOR MODEL YEAR. 09 = Manufacture month (9TH month) September. 3 = Year of manufacture 2003. 9955 = sequential chassis number. (9,955th built in this year.) “Alpha” model year codes Model engine size codes D = 2003 J = 2008 12 = 125cc E = 2004 K = 2009 20 = 200 model (175cc) F = 2005 L = 2010 25 = 250cc G = 2006 M = 2011 28 = 280 model (272cc) H = 2007 N = 2012 30 = 300cc So I am thinking it's a 2005 250cc now. Am I correct. Unsure about 300 cc
September 18, 20178 yr Author So am I correct thinking it's a 2005 250cc now. Or 2005 300 cc. Got me baffled now. I will go with changing the oil and checking it on the looking Glass. Any good oil recommended
September 18, 20178 yr 13 hours ago, bilks said: 550cc from empty but use your sight glass until it's half way up.2007 had a black frame. 2004 and newer (after July 2003) Example: VTRGG 3002 D093 9955 VTR = International manufacturers code. VTR = GasGas GG =Trial model (Company code to identify model EC = Enduro & MX, FS = Four Stroke, WD = Quads) 3002: 30 = 300 model. 02 = (02 = year of Europe homogulation N/A USA) D093: D = 2003 ALPHA CODE FOR MODEL YEAR. 09 = Manufacture month (9TH month) September. 3 = Year of manufacture 2003. 9955 = sequential chassis number. (9,955th built in this year.) “Alpha” model year codes Model engine size codes D = 2003 J = 2008 12 = 125cc E = 2004 K = 2009 20 = 200 model (175cc) F = 2005 L = 2010 25 = 250cc G = 2006 M = 2011 28 = 280 model (272cc) H = 2007 N = 2012 30 = 300cc Vtrgg3002f0740086 I would say based on the table above your VIN is for a 2005 model 300cc (also look on the cylinder flywheel side by the exhaust and you should see 30 stamped/cast into it) 3002 = 300 model with the 02 year of Europe homogulation F = 2005 07 = manufactured in July 4 = manufactured in 2004 0086 = 86th bike made As for gearbox oil, the Pro engine uses much less than the previous model engine. Takes approx 380cc, but of course watch the sight glass on the clutch cover and fill it to halfway or just above halfway. Which oil to use? there is a wide range of opinions on that............. Edited September 18, 20178 yr by zippy
December 6, 20232 yr 34 minutes ago, wayno57 said: Can someone tell me motor size? VTR GG 1694 10 94 0115 @wayno57 according to that it is a 163cc motor which should be a 1994 JT 160 , or called a 200 by some people , look on the cylinder it may be marked on there although it could have been converted to a 125cc at some stage in its life as those two capacities share the same crank/conrod assembly. If you want to be sure then drain the coolant and take the head off and measure the piston diameter , if its a 163cc it will be 64mm dia , if it is a 54mm it is a 125cc , the gearbox/clutch casings look the same on all the variants so it could have had a complete motor change at some point and be a 250 or larger , as i said you will know by the piston diameter. Edited December 6, 20232 yr by Tr1AL
December 6, 20232 yr Thanks. Bought this from a guy that told me it was a "95" 260cc. Not that the size matters for riding, being off a trials bike for quite some time (35 yrs) just want to bang around in my yard and woods. Usefully info for finding parts if needed.
December 7, 20232 yr 12 hours ago, wayno57 said: Thanks. Bought this from a guy that told me it was a "95" 260cc. Not that the size matters for riding, being off a trials bike for quite some time (35 yrs) just want to bang around in my yard and woods. Usefully info for finding parts if needed. If it actually is a 163cc then if it is tuned nicely and the piston and cylinder etc is in good order then it will have plenty of power for most mid weight riders , a better bike IMO than the earlier PRO models. Have fun.
