timp Posted March 12, 2018 Share Posted March 12, 2018 Following on from this thread has anyone similar issues or cures? Quote Link to comment Share on other sites More sharing options...
lotus54 Posted March 13, 2018 Share Posted March 13, 2018 I’d suggest the easy things first. 1. Choke off 2. Air box doesn’t have a rag or something left in it 3. Replace sparking plug (perhaps the easiest?) It could be just a bad electrical connection, or poor earth connection on the coil. Quote Link to comment Share on other sites More sharing options...
lineaway Posted March 13, 2018 Share Posted March 13, 2018 The bike comes lean jetting wise. While you are in there you get to see if the intake boot is torn or not installed correctly. Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted March 13, 2018 Share Posted March 13, 2018 When the 4t first came out a friend had problems with the bike not running properly. Turned out he was unaware of the hot start button and (I can't remember which way now) has assumed it was the choke and was running with the choke on all the time, or vice versa. Worth checking they are both in the correct setting? 1 Quote Link to comment Share on other sites More sharing options...
stu109 Posted March 18, 2018 Share Posted March 18, 2018 You say if the bike is brand new. If you bought from a dealer then the bike automatically comes with a six month warranty (even if bought from a dealer second hand). I would suggest that the dealer should be your first call before taking the thing apart. Quote Link to comment Share on other sites More sharing options...
section swept Posted March 19, 2018 Share Posted March 19, 2018 Questions the supplying dealer may ask you are, “ have you broken the engines in?” Have you shared the same fuel? As all are misfiring it could be stale fuel. Are the bikes misfiring or are you revving them too high and the limiters operating. Quote Link to comment Share on other sites More sharing options...
