July 2, 20188 yr Good evening During this hot weather at a Trial, the clutch is sticking/dragging a bit and hard to find neutral, at sections New bike - 3 trials use only Thinking of changing the oil How about using super expensive Elf HTX740, as I use in my 4RT clutch, will this make it drag less and improve things?
July 2, 20188 yr Be a good idea to change the oil now the bikes run in anyway.If you've already got the oil you mention try it,you've nothing to lose.
July 3, 20188 yr Author 8 hours ago, Nebulous said: You don’t say what clutch-plates you run in your 4RT. But I would certainly take those expectations , and your “super-expensive” oil - and apply them to your new purchase. Whatever clutch plates Honda put in the bike in 2007 when it was new, never had any bother using Elf 740 and clutch works fine in 4RT - why change the plates? Never had them out in 10 years+ My 4RT runs like a swiss watch, shame yours doesn't Edited July 3, 20188 yr by johnnyboxer
