Carl Brown Posted March 25, 2019 Share Posted March 25, 2019 Hi can anyone help I have recently bought a supposed factory 300 sherco 2015 . On the log book it says the engine no is SH25029994 , but on the engine it is SH30029994 . Also the cylinder head is black which when looking at other factory bikes they are blue or gold . It also has 4600 on the cylinder head . I think the factory engine might of been taken out and a 300 standard has been put in . Does any one know about these ? Thanks . Quote Link to comment Share on other sites More sharing options...
neils on wheels Posted March 25, 2019 Share Posted March 25, 2019 I would take it back to the seller and ask him/her why the nos. do not match. Quote Link to comment Share on other sites More sharing options...
ChrisCH Posted March 25, 2019 Share Posted March 25, 2019 (edited) I fitted a new engine to a Suzuki many years ago. If you send the V5 back the DVLA change the engine number for you free of charge, so it is not a very big problem. The engine numbers in the OP are odd, in that the first three digits look very much like CC. If so then the bike was a 250 which has had a 300 engine fitted later. I don't know enough about the bikes to say if the engine is a "factory" edition or not. I would think the importers could quickly find out. The engine number and the V5 should match - this is a sign that something has been altered. If the engine had been legitimately changed at some point the V5 should have been changed to show the new engine number. I suggest that the OP uses the DVLA system to check the registration number of the bike. It should show the bike's details and that it is SORN (I assume it is), but it will give you the engine CC and taxation class. If it shows as a 250 then you will have solved the mystery, but not what to do about it. https://www.gov.uk/get-vehicle-information-from-dvla Edited March 25, 2019 by ChrisCH Quote Link to comment Share on other sites More sharing options...
Carl Brown Posted March 25, 2019 Author Share Posted March 25, 2019 4 hours ago, neils on wheels said: I would take it back to the seller and ask him/her why the nos. do not match. I think thats next yes , cheers . Quote Link to comment Share on other sites More sharing options...
Carl Brown Posted March 25, 2019 Author Share Posted March 25, 2019 1 hour ago, ChrisCH said: I fitted a new engine to a Suzuki many years ago. If you send the V5 back the DVLA change the engine number for you free of charge, so it is not a very big problem. The engine numbers in the OP are odd, in that the first three digits look very much like CC. If so then the bike was a 250 which has had a 300 engine fitted later. I don't know enough about the bikes to say if the engine is a "factory" edition or not. I would think the importers could quickly find out. The engine number and the V5 should match - this is a sign that something has been altered. If the engine had been legitimately changed at some point the V5 should have been changed to show the new engine number. I suggest that the OP uses the DVLA system to check the registration number of the bike. It should show the bike's details and that it is SORN (I assume it is), but it will give you the engine CC and taxation class. If it shows as a 250 then you will have solved the mystery, but not what to do about it. https://www.gov.uk/get-vehicle-information-from-dvla Thanks for that , just done it and its come back as a 250 . Which isnt whats in it . Quote Link to comment Share on other sites More sharing options...
Carl Brown Posted March 25, 2019 Author Share Posted March 25, 2019 16 minutes ago, faussy said: I find it rather odd that the last 5 numbers are identical. These should be different regardless of capacity. No two engines should have this same number. Possibilities could be a complete engine change by the dealer with a request to retain engine numbers (which can be possible i think), but then why the change in capacity. Or a mistake in quoting the bikes engine number Regarding the head, that is a regularly changed part so you can't form much basis from that alone. Its really strange , there is definatley something untoward going on . Going to get intouch with main dealer tomorrow and see what they say . Quote Link to comment Share on other sites More sharing options...
Carl Brown Posted March 25, 2019 Author Share Posted March 25, 2019 25 minutes ago, Carl Brown said: Its really strange , there is definatley something untoward going on . Going to get intouch with main dealer tomorrow and see what they say . The bloke I bought it off (a dealer) said he has been in-touch with sherco ( this was last Thursday) and they said it was a 250 . But it was pointed out to me on Sunday at Cowm quarry that the front engine bolt was working loose and the engine nos state its a 300 . Also the carb isnt one that comes on a factory bike . I know this is all confusing , but this is why Ive asked . My head is up my axxe with it all . Quote Link to comment Share on other sites More sharing options...
Bilko Posted March 25, 2019 Share Posted March 25, 2019 Simple take t back not as described Sherco should know if the reg or vin is a Factory. Edition http://www.BLOCKED LINK.com/2015-sherco-factory-trial/ Quote Link to comment Share on other sites More sharing options...
collyolly Posted March 25, 2019 Share Posted March 25, 2019 At least you got it from a dealer, he or you should talk to the importer for best advice. Quote Link to comment Share on other sites More sharing options...
parsy Posted March 25, 2019 Share Posted March 25, 2019 If I was in your shoes carl I wouldn't hesitate , just take it back to the seller (dealer) and get your money back !! sounds like trouble and a can of worms !! someone is having somebody's pants down along the line here . If your new to the game you want something wots right from the off . Quote Link to comment Share on other sites More sharing options...
ChrisCH Posted March 26, 2019 Share Posted March 26, 2019 Are you sure it is a Sherco? In my day these bikes were known as a Bitza. (sorry) Quote Link to comment Share on other sites More sharing options...
Husie200 Posted March 28, 2019 Share Posted March 28, 2019 Anything Sherco related, I would contact Malcolm Rathmell Sport on 01423 772885 as they would have been the original importers and will have a record of it from new. I contacted them regarding my 2001 Sherco 200 and they had all the original records about the bike and couldn't have been more helpful. Quote Link to comment Share on other sites More sharing options...
