March 28, 20197 yr Can you fit a later model water pump (upgraded) directly to a 2013 TXT 300 Sick and tired of the old type seal failing !!!!!!
March 28, 20197 yr Author Am about to replace the shaft, impellor and seal for the 3rd time in 3 years. Seals keep failing allowing the coolant to drain into the gear box
March 28, 20197 yr Are you using genuine seals, and new shaft every time? how long does it last before happening again?
March 28, 20197 yr Author yes, using genuine parts. Seems to last about a year. So can I fit the post 2015 model pump ??????
March 29, 20197 yr Yes the post 2015 water pump is a direct replacement for the earlier 2003 - 2014 units. Fits straight on. Edited March 29, 20197 yr by arnoux
March 30, 20197 yr You may be getting high pressures in the water system. Can be caused by the Cylinder head o-ring and or radiator vent pipe kinked,
