April 27, 20197 yr Evening people, in the proccess of re assembling my 159 after a slight resto back to standard and really atuck on what bars to opt for? What height and make of bar do people opt for? Thanks in advance
April 28, 20197 yr In Motion are the go here. I have 5 and a half inch Renthals on my 3 Sherpas but they also have black steel ones the same as the original Bultaco ones. The bend is basically the same as the Renthals. The Renthals come in either 5.5 and 6 inch height.
April 28, 20197 yr Author 1 hour ago, bullylover said: In Motion are the go here. I have 5 and a half inch Renthals on my 3 Sherpas but they also have black steel ones the same as the original Bultaco ones. The bend is basically the same as the Renthals. The Renthals come in either 5.5 and 6 inch height. Cheers ?
May 2, 20197 yr Author 15 minutes ago, guys said: I'm 180cm tall and went for the 6 inch Renthals for my 159. Same height as myself, comfortable at that height? With the lower bars I always felt hunched over.
May 2, 20197 yr 45 minutes ago, WJSmith said: Same height as myself, comfortable at that height? With the lower bars I always felt hunched over. Yes, very comfortable. It creates the same position as on my Montesa 300RR.
May 13, 20197 yr Original handlebars where made out of steel with an extra bar in the middle. That was the standard set up for mostly all bikes back then and guess what these handlebars where not heavier the the aluminium bars of today I still have some steel ones from Bultaco, Italjet, Montesa and SWM (which was for the export bike model TL.NW yellow at the MK II from 1980).
May 13, 20197 yr The original bars for the 159 were about 8 inch rise as were virtually all of the bikes from that era, with no brace. The black braced bars came in about 1978/79 on the M198/199 I think
May 14, 20197 yr The high steel ones where heavy and bent easely, the steel ones are (still) quite good.
May 14, 20197 yr Pretty sure the !59 came with 5 1/2 chrome bars. The 199 came with black steel bars without a brace and the 199A came with black steel bars with a brace
