July 31, 20197 yr Are they really like rocking horse...... I am looking for a left hand " Alloy" rear brake pedal for a 199a. Has anybody got one laying around for sale please. Thanks
July 31, 20197 yr Author Sorry no, when the bike was built I was told reverting to a left hand rear brake would work better, and to facilitate this the bike builder had an ugly steel after market one fitted. When back in his workshop recently I saw a nice alloy version , that I was told was avaliable from bultaco and fitted to models in the past or as an aftermarket part. Thats the one I am after or at a push I will get my friendly engineer to make one...
August 1, 20197 yr yes rocking horse pooh. I had an alloy one but not sure if it was left or right, will look. Only advantage is a rod can be fitted which gives a far superior brake using the standard hub. Ive changed to a yamaha hub so get rh rod. Edited August 1, 20197 yr by nigel dabster
August 1, 20197 yr Feetupfun - I was about to post "Like this one"........but you beat me to it ..........
August 2, 20197 yr I am lucky to have an alloy one on my 199 and have never seen another. As said above far superior brake on the left being a direct rod rather than a cable
August 2, 20197 yr Author Well I am hoping that someone might have got fed up and converted to the more normal RHS and have one spare.... its not easy jumping from bike to bike and then forgetting which side the back brake is on...
August 2, 20197 yr Maybe I'm a little special? Ive never had an issue jumping from bike to bike, left or right gear shift, race pattern box or standard. Although I do have to admit to thinking for the first lap on my '68 TSS right hand shift and upside down, 1 up 4 down The most excitement for me comes from jumping from one of my modern bikes to an old bike and realising the brakes don't work!
August 3, 20197 yr 9 hours ago, gooey said: Hi, theres one on ebay now. If you mean item # 264418176169 on eBay UK, that's right side fitting, and steel........ What the OP wants is an alloy LEFT side lever :- like this one removed from my model 159, and shown here with an alloy right side lever of the type which would have been fitted to his 199A originally. I think most of these alloy levers were replaced from choice with aftermarket steel fabricated levers - seems metisse is going the other way ! Edited August 3, 20197 yr by lorenzo additional info.
August 4, 20197 yr gooey - Yes, you're quite correct - hadn't seen that one ! I tend to look no further than the UK site, otherwise it can get VERY expensive........
August 4, 20197 yr Hi Lorenzo I know what you mean about the price but sometimes you can only find some Bultaco parts in Spain or USA ?
August 8, 20197 yr Author The steel one shown a couple of posts above is the one I have fitted... don t like the look at all...... the alloy one is what I need ..
