2013 gasgas txt pro ,clutcch not disengaging
tugg
Hi I have acquired a 2013 gasgas 250 and the clutch is not disengaging , I have bled the system and it is still the same , I decided to take the cover off and take a look and couldn't see anything obvious , I I un done the basket but couldn't undo the pressure plates because of the odd size bolts , anyone have any ideas what it could be ,also what size socket or tool fits the pressure plate bolts. cheers
Is not disengaging at all,or dragging?Does the fluid level drop,if so I would look at the slave cylinder,if not I would do as Nigel says and check the clutch pack thickness,should be 9.85 mm.
Please sign in to comment
Sign In Now
