yam175 Posted December 17, 2019 Share Posted December 17, 2019 More monty questions, what pre mix are you using ,have done a search but throws loads of different answers Quote Link to comment Share on other sites More sharing options...
yam175 Posted December 17, 2019 Author Share Posted December 17, 2019 In my 348 thanks Quote Link to comment Share on other sites More sharing options...
suzuki250 Posted December 17, 2019 Share Posted December 17, 2019 I use 40:1 on my air cooled bikes, never had a problem Quote Link to comment Share on other sites More sharing options...
timdog Posted December 17, 2019 Share Posted December 17, 2019 Interesting article on classictrial.co.uk under heading technical then 2t explaining how different oil is now compared to back when twinshocks were new. Recommends 70:1 for air cooled Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted December 17, 2019 Share Posted December 17, 2019 50:1 in my Cota 247 and SWM works well. Quote Link to comment Share on other sites More sharing options...
yam175 Posted December 17, 2019 Author Share Posted December 17, 2019 1 hour ago, suzuki250 said: I use 40:1 on my air cooled bikes, never had a problem Semi or fully syn Quote Link to comment Share on other sites More sharing options...
yam175 Posted December 17, 2019 Author Share Posted December 17, 2019 47 minutes ago, timdog said: Interesting article on classictrial.co.uk under heading technical then 2t explaining how different oil is now compared to back when twinshocks were new. Recommends 70:1 for air cooled I will give it a read thanks Quote Link to comment Share on other sites More sharing options...
section swept Posted December 17, 2019 Share Posted December 17, 2019 These engines were designed when the oils were what was available at the time. Now modern oils can be used more sparingly, so the mix ratios can be reduced. However those newer ....technical.... oils can still be mixed at the old ratios 40 or 50:1 purely for peace of mind....I run my 348 on 50:1 synthetic. Quote Link to comment Share on other sites More sharing options...
suzuki250 Posted December 18, 2019 Share Posted December 18, 2019 (edited) 13 hours ago, yam175 said: Semi or fully syn I use Silkolene comp 2 which is synthetic I did use Castrol power 1 which also worked well it's also worth noting that Castrol and some other manufactures state a maximum of 50:1 Edited December 18, 2019 by suzuki250 Quote Link to comment Share on other sites More sharing options...
yam175 Posted December 18, 2019 Author Share Posted December 18, 2019 Thanks again guys , I'll drop the oils sometime this week , and hope to have a ride out over the Christmas period ? Quote Link to comment Share on other sites More sharing options...
teamferret Posted December 18, 2019 Share Posted December 18, 2019 The guy who does most of the reboring and such work around here, maintains that bikes with a cast iron liner can't go lower than 25:1 as the clearence has to be more than a coated bore and the gap is too large for the diluted oil to fill Quote Link to comment Share on other sites More sharing options...
