woody Posted October 8, 2020 Share Posted October 8, 2020 29 minutes ago, bullylover said: That inner basket is the wrong one for a 159. A 159 should have nuts to hold the clutch springs in not pins. I think most of the later Sherpas all use the same clutch but I`m not sure when they changed from the pins to the nuts. But any clutch inner basket that used nuts should work. 159 is a pin type hub, I've not seen one with the threaded type. 1 1 Quote Link to comment Share on other sites More sharing options...
Phillip1 Posted October 8, 2020 Author Share Posted October 8, 2020 Lots of different opinions as to type of correct clutch and shaft spacers ! Due to the horrendous amount of damage to the inside of my old clutch case caused by rubbing in a rotary motion and no damage to the ends of the clutch spring mounting studs, or the small 2mm.retaining pins and washers,it appears the clutch centre hub has previously been replaced. As the clutch retaining centre nut and the crankshaft flywheel nut were both only finger tight,when I received the bike,it is possible both crankshaft and gearbox mainshaft spacer collars have been changed. I assume due to age of the bike,no Micro Fiche or part number lists exist ? Quote Link to comment Share on other sites More sharing options...
noel063 Posted October 8, 2020 Share Posted October 8, 2020 Google sherpamanuelsolar.blogspot.com there is info which may help. It’s definitely a cup and pin arrangement and not nuts Quote Link to comment Share on other sites More sharing options...
Phillip1 Posted October 8, 2020 Author Share Posted October 8, 2020 Hi,comes up as Blog does not exist,any other way to access ? Quote Link to comment Share on other sites More sharing options...
noel063 Posted October 8, 2020 Share Posted October 8, 2020 Hi, try Bultaco Sherpa T350 Manuel Solar Quote Link to comment Share on other sites More sharing options...
noel063 Posted October 8, 2020 Share Posted October 8, 2020 2 hours ago, Phillip1 said: Hi,comes up as Blog does not exist,any other way to access ? Just tried it on the laptop and it came up fine Quote Link to comment Share on other sites More sharing options...
bullylover Posted October 9, 2020 Share Posted October 9, 2020 Wow. I have had 3 Australian 159s apart and they all had nuts to hold the clutch springs in as well as a few 158s were the same. We must have been lucky over here. Mine has nuts on it. 1 Quote Link to comment Share on other sites More sharing options...
Phillip1 Posted October 9, 2020 Author Share Posted October 9, 2020 Hi Bullylover,it must be something to do with the climate the bike is being exported to ? Do you have a measurement for overall length of the threaded pins,as maybe thats the type of hub I nead ? 1 Quote Link to comment Share on other sites More sharing options...
vintagenut Posted October 9, 2020 Share Posted October 9, 2020 Hi Phillip, Well... disregard what I mentioned about the distance between the clutch spacer and seal surface. My memory of working on the 159 was too foggy to accurately recall. I cracked open the clutch cover last night to take a few measurements and photos (attached). All seem to be in line with the measurements Woody provided as well as confirming his description of the 159 clutch hub (original to mine, anyway) incorporating studs with pin retainers NOT threaded. On the off-chance you simply have a weird clutch cover, I did measure mine internally using a straight edge and came up with 72mm taken from the ledge of the threaded access port for external clutch adjustment (see photo). Hope this helps a bit. Good luck! 2 Quote Link to comment Share on other sites More sharing options...
Phillip1 Posted October 9, 2020 Author Share Posted October 9, 2020 Hi Mr.Vintagenut and thank you for supplying the measurements. Can you confirm your 72.02mm. was from the case gasket face to the inner clutch cover to next to the threaded access hole ? My replacement clutch cover measures only 67.1mm and the old damage original clutch cover measures very similar,allowing for the damage caused by the rotation clutch pins. So it appears both my covers are 5mm. too shallow. My clutch shaft top hat spacer looks to be the same height as yours. Problem is what to do now,as I cannot keep buying old clutch covers on the off chance of finding a deeper one ? Quote Link to comment Share on other sites More sharing options...
vintagenut Posted October 9, 2020 Share Posted October 9, 2020 Confirmed - measures from the gasket surface to the point mentioned. For comparison sake, I also measured the cover from my 199a. As you can see, the factory removed the step that can be seen on the 159 cover, gaining an additional 3mm clearance - 75mm depth total (attached). Does seem your cover is from another model or lost 5mms worth of material on a sanding table. Cheers- Christian Quote Link to comment Share on other sites More sharing options...
feetupfun Posted October 10, 2020 Share Posted October 10, 2020 (edited) 5 hours ago, Phillip1 said: Problem is what to do now,as I cannot keep buying old clutch covers on the off chance of finding a deeper one ? You could get the seller to measure. If you can say which design cover you want I can measure some up for reference Edited October 10, 2020 by feetupfun Quote Link to comment Share on other sites More sharing options...
Phillip1 Posted October 10, 2020 Author Share Posted October 10, 2020 Hi Christain, can you confirm a 199a clutch cover will fit a 159 crankcase ? As a 199a clutch cover may solve my problem. Quote Link to comment Share on other sites More sharing options...
vintagenut Posted October 10, 2020 Share Posted October 10, 2020 Confirmed - fits perfectly. No visible gaps - all screws seat correctly. I've included a pic taken through the access cover to illustrate clutch hub clearance. No contact there. When shopping for a replacement, definitely follow Feetup's advice in getting a measurement from the seller. Shouldn't be too much to ask of the seller if reputable. Cheers! C. 1 Quote Link to comment Share on other sites More sharing options...
Phillip1 Posted October 10, 2020 Author Share Posted October 10, 2020 Thank you for your help Christain. Looks to be 5 or 6 mm clearance there over the clutch studs,so I need to find a 199a case,preferably without the inside boss. Your caseing looks to be a more accurate casting then the earlier 159 case,do they not counter bore the mounting cap heads ? Quote Link to comment Share on other sites More sharing options...
