Ftwelder Posted November 26, 2020 Share Posted November 26, 2020 My original IRZ is working just fine and with very low miles I decided to try replace it before wearing it out further. I purchased a Taiwan made OKO kit from Mid-Atlantic trials (I am in the states) and wonder if any of you had gone this route? The tuning seems straight-forward. 2 Quote Link to comment Share on other sites More sharing options...
feetupfun Posted November 26, 2020 Share Posted November 26, 2020 Yes they have been a good thing on every old two stroke trial-type motor I've put one on so far 1 Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted November 26, 2020 Share Posted November 26, 2020 I agree with feetupfun. Put one on my SWM and it pulls much better from the bottom of the range and runs cleanly throughout. Mid Atlantic are a good company to deal with and have worked hard to get the OKOs properly dialled in for specific models. 2 Quote Link to comment Share on other sites More sharing options...
bullylover Posted November 26, 2020 Share Posted November 26, 2020 I have one on all of my 3 Sherpa Ts and they all work very well. Easy to get right and the D slide ones have much better pull right off the bottom. 1 Quote Link to comment Share on other sites More sharing options...
teamferret Posted November 26, 2020 Share Posted November 26, 2020 Is there anywhere in the UK to get OKO's from? Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted November 26, 2020 Share Posted November 26, 2020 I looked into that and the answer is no. The previous importer no longer does them. You can find cheap Chinese copies on eBay, marketed as OKOs, but they're not worth having by all accounts. I dealt with Mid Atlantic Trials in USA and found them excellent. Cost was about 118 quid delivered and set up ready for my bike, with some extra jets and hose to attach to air box. I think that compares quite well with buying a new Amal or Mikuni in the UK. If you take a look at Mid Atlantic's website you'll be able to read about what they do with OKOs. Quote Link to comment Share on other sites More sharing options...
Ftwelder Posted November 26, 2020 Author Share Posted November 26, 2020 It seems I only need to shorten the throttle cable housing 17mm and it should bolt right on! Quote Link to comment Share on other sites More sharing options...
woody Posted November 26, 2020 Share Posted November 26, 2020 1 hour ago, teamferret said: Is there anywhere in the UK to get OKO's from? Nowhere, only copies Buy direct from here https://www.ebay.co.uk/itm/OKO-26mm-RACING-CARB-FLAT-SLIDE-CARBURETTOR/302886110025?hash=item46856b4349:g:rRQAAMXQHO9Re1yr Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted November 26, 2020 Share Posted November 26, 2020 5 hours ago, woody said: Nowhere, only copies Buy direct from here https://www.ebay.co.uk/itm/OKO-26mm-RACING-CARB-FLAT-SLIDE-CARBURETTOR/302886110025?hash=item46856b4349:g:rRQAAMXQHO9Re1yr I didn't know about that source, have you tried it yourself? Would be interested to hear your experience if so. Half the price of the ones from Mid Atlantic but are they the same, ie genuine OKO? Also a question of how they're jetted I suppose. Quote Link to comment Share on other sites More sharing options...
woody Posted November 26, 2020 Share Posted November 26, 2020 Genuine OKO yes, I've been buying off them for about 10 years. For virtually every bike I've put them on they run virtually straight from the box with minimal change, usually drop the needle one notch and maybe down one size on the pilot jet. Jets are standard Keihin. They come with 112 main and 48 pilot. I've never had to change the main jet. Out of interest I bought one from Mid Atlantic a couple of years ago jetted for a 310 MAR, I wanted to see what differences there were in jetting from how I had mine jetted. It came with a weaker needle but bigger pilot jet. The bike ran the same with either carb 2 Quote Link to comment Share on other sites More sharing options...
Ftwelder Posted November 26, 2020 Author Share Posted November 26, 2020 1 hour ago, woody said: Genuine OKO yes, I've been buying off them for about 10 years. For virtually every bike I've put them on they run virtually straight from the box with minimal change, usually drop the needle one notch and maybe down one size on the pilot jet. Jets are standard Keihin. They come with 112 main and 48 pilot. I've never had to change the main jet. Out of interest I bought one from Mid Atlantic a couple of years ago jetted for a 310 MAR, I wanted to see what differences there were in jetting from how I had mine jetted. It came with a weaker needle but bigger pilot jet. The bike ran the same with either carb Months ago I bought a random 26mm OKO off ebay to use as a mock-up for my BSA and it ended up being legit. My new one should arrive tomorrow so Ill compare the internals myself. Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted November 26, 2020 Share Posted November 26, 2020 2 hours ago, woody said: Genuine OKO yes, I've been buying off them for about 10 years. For virtually every bike I've put them on they run virtually straight from the box with minimal change, usually drop the needle one notch and maybe down one size on the pilot jet. Jets are standard Keihin. They come with 112 main and 48 pilot. I've never had to change the main jet. Out of interest I bought one from Mid Atlantic a couple of years ago jetted for a 310 MAR, I wanted to see what differences there were in jetting from how I had mine jetted. It came with a weaker needle but bigger pilot jet. The bike ran the same with either carb Thanks, appreciate the reply. Thinking of trying one on my Cota 247 - nothing wrong with the standard Amal but I was so impressed by putting an OKO on the SWM that for 60 odd quid it's worth a try. 1 Quote Link to comment Share on other sites More sharing options...
Ftwelder Posted November 28, 2020 Author Share Posted November 28, 2020 I finished installation and it started first kick. I tried using the stock rubber spacer with the adapter spigot supplied and had a big air leak once the bike warmed up. I righted that and adjusted the idle circuit. It's very close to perfect. Ill raise the needle a little tomorrow and see if the acceleration can be improved. I like it so far. 2 Quote Link to comment Share on other sites More sharing options...
Triad Posted December 8, 2025 Share Posted December 8, 2025 Sorry to resurrect a 6 years old topic but... was it the model with or without the "powerjet"? I just fitted one of the chinese PWK clones on my 250 Pioneer engine with Explorer exhaust... the stock jetting seems to be too lean (38 idle jet, 120 main). I just replaced the idle with a 45 as the bike tends to die even with the air mixture screw totally closed. Not sure the 120 main is big enough, we'll see. 1 Quote Link to comment Share on other sites More sharing options...
feetupfun Posted December 9, 2025 Share Posted December 9, 2025 6 hours ago, Triad said: Sorry to resurrect a 6 years old topic but... was it the model with or without the "powerjet"? I just fitted one of the chinese PWK clones on my 250 Pioneer engine with Explorer exhaust... the stock jetting seems to be too lean (38 idle jet, 120 main). I just replaced the idle with a 45 as the bike tends to die even with the air mixture screw totally closed. Not sure the 120 main is big enough, we'll see. Non-powerjet. If you want an OKO, the model is K-100 and people usually run a 26mm or 28mm 1 Quote Link to comment Share on other sites More sharing options...
