Backerlee Posted December 13, 2020 Share Posted December 13, 2020 Hi folks need help, sherco 290 firstly its been running fine however fired it up Sunday and after a million kicks it fired up but was mis firing big time then started bellowing smoke that smells of burning rubber. It won't tick over and the engine isn't knocking or anything. Any ideas folks Quote Link to comment Share on other sites More sharing options...
Creepytheclutchmaster Posted December 13, 2020 Share Posted December 13, 2020 3 hours ago, Backerlee said: Hi folks need help, sherco 290 firstly its been running fine however fired it up Sunday and after a million kicks it fired up but was mis firing big time then started bellowing smoke that smells of burning rubber. It won't tick over and the engine isn't knocking or anything. Any ideas folks Sound like the clutch side main bearing seal has failed and its sucking up gearbox oil and burning it. Take the carb and reed valve off and you will be able to tell if its sucking oil in. Quote Link to comment Share on other sites More sharing options...
Creepytheclutchmaster Posted December 13, 2020 Share Posted December 13, 2020 Or the head gasket or bace gasket may have failed and your burning abit or antifreeze. Quote Link to comment Share on other sites More sharing options...
mcman56 Posted December 14, 2020 Share Posted December 14, 2020 A sheared key and rotated flywheel could alter timing and have a similar result. Quote Link to comment Share on other sites More sharing options...
Backerlee Posted December 14, 2020 Author Share Posted December 14, 2020 Cheers gents I'll keep you informed, An after thought probably unrelated but kicking it up there is a point in rotation that will literally take my weight all 13.5 stone, I've had loads of 2 strokes and never had one this hard to kick is that normal? Quote Link to comment Share on other sites More sharing options...
Backerlee Posted December 14, 2020 Author Share Posted December 14, 2020 The sheared key looks the likely cause mate thanks Quote Link to comment Share on other sites More sharing options...
jonboy883 Posted December 14, 2020 Share Posted December 14, 2020 (edited) I'm a bit heavier than you and a 290/300 will sometimes take my weight on the kicker at the right point. Normally either exactly TDC or the complete opposite at the base of the stroke. if it's not the woodruff key, make sure the stator plate screws are all tight and the stator hasn't moved round a bit...... Edited December 14, 2020 by jonboy883 Quote Link to comment Share on other sites More sharing options...
Backerlee Posted December 14, 2020 Author Share Posted December 14, 2020 Wood ruff key definitely gone bud so stator could be anywhere on the shaft so its got to be that, I'm just relieved its not something drastic that I can do myself, thanks for the kick start info. It just means my son was right. I am a pussy Quote Link to comment Share on other sites More sharing options...
Creepytheclutchmaster Posted December 20, 2020 Share Posted December 20, 2020 Why would a broken woodruff key make it smell like burning though?, shurly that would just affect the timeing and stop it from starting and running normally. I had a woodruff key snap on a yz125 and it just stopped it running starting, occasionally poped and spluttered. It Didn't make it smell like burning. Quote Link to comment Share on other sites More sharing options...
Backerlee Posted December 20, 2020 Author Share Posted December 20, 2020 It was pushing the fuel into the exhaust then firing it. Burning the oil build up in the pipe, that's my theory anyway. However got it all back together and it won't start at all now so £@?@ knows Quote Link to comment Share on other sites More sharing options...
Creepytheclutchmaster Posted December 20, 2020 Share Posted December 20, 2020 Could be, I still think your head or bace gasket have gone, as burning fuel in the exhaust pipe or first muffler box will still usually only smell like 2 stroke, I cleaned my mid box with a blowtorch and it didn't smell like burning rubber, the acrid smell sounds like burning antifreeze.take the carb and reed valve off if it's sucking in enough antifreeze to stop it running you should be able to see little green droplets condensating on the con rod and back of the Piston (depending on the colour of your antifreeze). Quote Link to comment Share on other sites More sharing options...
Backerlee Posted December 20, 2020 Author Share Posted December 20, 2020 Thanks mate your probably right I'll have a look when I get chance and let you know Quote Link to comment Share on other sites More sharing options...
Backerlee Posted December 21, 2020 Author Share Posted December 21, 2020 Just to update, proper wood ruff key came today. ( I'd bodged one that nearly fit) now fitted with timing retarded 5mm and it started 2nd kick and runs a treat. As for dodgy smells I'm still no wiser but the bellowing smoke has gone so who knows what that was Quote Link to comment Share on other sites More sharing options...
b40rt Posted December 22, 2020 Share Posted December 22, 2020 (edited) 13 hours ago, Backerlee said: Just to update, proper wood ruff key came today. ( I'd bodged one that nearly fit) now fitted with timing retarded 5mm and it started 2nd kick and runs a treat. As for dodgy smells I'm still no wiser but the bellowing smoke has gone so who knows what that was If the timing was very advanced the engine / exhaust would run at very high temperature, it could have been crap getting burnt out, hopefully ! Edited December 22, 2020 by b40rt Quote Link to comment Share on other sites More sharing options...
Backerlee Posted December 22, 2020 Author Share Posted December 22, 2020 Hopefully mate 1 Quote Link to comment Share on other sites More sharing options...
