Rebuild a 250 Alpina 1974 type 115
Leave the bent cylinder fins - any attempt to straighten will likely snap them. No head gasket - spigoted joint.
  • Replies 158
  • Views 37.6k
Most Popular Posts
  • Finally, from (without registration):  To : New  seat New OKO carburator New tires Tank restored  with new petcock New chain and sprockets Bottom engin rebuilt
  • I use a socket with the OD machined down to fit onto that nut. Yes a clutch holding tool is required the way you are doing the work, but if you are going to pull a Bultaco motor apart again, cons
  • Engine is out 🙂, I wish to open it asap but the frame is the priority...
On 12/12/2021 at 3:06 AM, Divouneh said:
Cleaning from my workshop for the next phase 😗...
I just noticed that the frame in your photo is different to a 115 frame and a 116 frame I have here. Yours is missing some frame elements that connect the rear uprights to the central rear down-tube. Your model 115 frame looks like my model 138 frame in that section of the frame. Your headstock gusseting looks the same as these 115/116 frames which is different to the 137/138 frame. The 137/138 models followed the 115/116 models so I'm wondering if your frame may be near the end of the production of of the model 115.
Here are photos of the model 115 and model 116 frames I am referring to
Edited by feetupfun
Hi feetupfun, I'm curious which bits you're referring to at the rear of the frame. I have a very late M116 frame which has had a few things cut off and added on and I am curious to see how they compare. It would also be a good reference for putting mine back to stock.
Thanks
Crank inspection without opening: play from the connecting rod
0.5 mm when 2.5 is allowed.
I will change the crank seals left and right, no opening from the main casing scheduled yet ( Will we inspect more after the opening from the clutch casings  and seals removed).
I see to options: engine rebuilt or very low hours, the sprockets are also "clean" which is another good  indication ..
Spare parts issues :
oil seal foe the shifter ?
Oil seal engine sprocket ?
The main seals are easy to find (kit with bearings) but these two 👀...
Thank you
Gearbox sprocket oil seal    (Bultaco part #160-001)    30 x 40 x 7mm.
Gearchange shaft seal        (Bultaco part #160-004)   14 x 24 x 7mm.
These are conventional lipped garter-type seals - should be obtainable from your local bearing/seal supplier.
Thanks
I have marked the frame elements red in this photo
Ah thanks, I hadn't seen that Divouneh's frame was lacking that extra loop. Mine does have that. One of these days I should start a frame thread, but I'll have to find the cable for my camera first.
Today, not a good news: the oil level was low in the gear box, quite half from the requested volume 😏
We have to recognize that the maintenance is not easy, to drain to check the oil volume.
What is your experiences with this oil level practice? 🧐
I'm quite interested in the development in the design of Bultaco frames, especially Alpinas and Sherpa Ts.
