Ninja Posted July 22, 2022 Share Posted July 22, 2022 Hi all just returning a heavily modified 199b back to original and seem to have a clutch problem, first off the clutch arm has been extended (more throw, lighter action maybe) and also with both balls and rod in position to set up centre adjuster I screw in to just touch top hat and back out 1/4 turn, but it only leaves about 3 threads on centre pin, not good, I'm thinking the rod is too short maybe, I would like to see some threads above nut face at least, any measurements would be helpful, clutch is operating OK, or maybe a problem at the lever side🤔 Cheers. Quote Link to comment Share on other sites More sharing options...
pschrauber Posted July 22, 2022 Share Posted July 22, 2022 (edited) Might be the rod is to short, I can measure the reserve rod (original!) to my 199b up. Then the ball on the lever end might be worn a bit too and the ball that is fitted to the clutch basket side might be of wrong diameter? Last not least is the right mushroom bearing mounted? How the adjusted clutch look of my 199b and too in full working order: Edited July 22, 2022 by pschrauber spelling issues as usual Quote Link to comment Share on other sites More sharing options...
Ninja Posted July 22, 2022 Author Share Posted July 22, 2022 Hi buddy thanks for the reply, the bearing is fitted to the mushroom, not sure if balls are correct size. Some measurements would be great. 👍 Quote Link to comment Share on other sites More sharing options...
bullylover Posted July 23, 2022 Share Posted July 23, 2022 The ball in between your pushrod and the mushroom should be the same size as the pushrod. 2 Quote Link to comment Share on other sites More sharing options...
pschrauber Posted July 23, 2022 Share Posted July 23, 2022 So I made the measurements The rod is exactly 190mm in length and exactly 5.5mm in diameter. The pushrod is 40mm in length, The mushroom bearing is 3mm in thickness and the edged washer 1.5mm. The balls are 5,0 to 5,5mm in diameter, there are two one between the pushrod and the rod and a second mounted to the clutch lever in the sidecases. See in the photo. 4 Quote Link to comment Share on other sites More sharing options...
woody Posted July 23, 2022 Share Posted July 23, 2022 Has it got the original steel plates or a fibre clutch. Fibre clutch will make the clutch pack thicker and put more space between the adjuster and mushroom meaning the adjuster has to be screwed in further 4 Quote Link to comment Share on other sites More sharing options...
sherpa325 Posted July 23, 2022 Share Posted July 23, 2022 There is also a difference between Surflex and Barnett clutch plates. If you are using a standard clutch [all steel plates] it's a very simple design, maybe you have an extra steel plate in there? 2 Quote Link to comment Share on other sites More sharing options...
Ninja Posted July 24, 2022 Author Share Posted July 24, 2022 Hi all thanks for the comments, when I bought this bike it was modified quite a bit, so trying to put things right, the clutch basket nut was loose, all parts are there 2 balls, rod, mushroom, bearing not sure if there was a 'washer' in there, if not where does it belong, was thinking of a fibre clutch, obviously less plates but thicker I'm assuming. Quote Link to comment Share on other sites More sharing options...
sherpa325 Posted July 24, 2022 Share Posted July 24, 2022 Should only be one ball and the fibre clutches as so much better in operation. Not sure what the thickness ends up being as you use less plates in total, but similar to the original. Surflex comes as a kit with new steels and springs 2 Quote Link to comment Share on other sites More sharing options...
Ninja Posted July 24, 2022 Author Share Posted July 24, 2022 I suppose as long as the 'stack height' is the same as a full set of steels, should be good to go. Quote Link to comment Share on other sites More sharing options...
Melbutcher Posted June 24, 2023 Share Posted June 24, 2023 Right now it seems like I have the same issue, I was wondering if you resolved it. Quote Link to comment Share on other sites More sharing options...
bullylover Posted June 27, 2023 Share Posted June 27, 2023 On that photo it looks like there is a ball bearing missing or there is one to many clutch plates in there. Quote Link to comment Share on other sites More sharing options...
Melbutcher Posted June 27, 2023 Share Posted June 27, 2023 Thanks for the advice, I’ll open it up further and let you know what I find, how many plates should it have? I counted 6 and 6. Quote Link to comment Share on other sites More sharing options...
bullylover Posted June 28, 2023 Share Posted June 28, 2023 Just going from memory I think there are 6 drive plates and 5 driven plates. Try that and see how that works. Quote Link to comment Share on other sites More sharing options...
slowrider Posted June 28, 2023 Share Posted June 28, 2023 take out the one ball, should not be 2 Quote Link to comment Share on other sites More sharing options...
