September 15, 20224 yr HI, DOES ANYONE RUN A 250 SHERPA ON A 26mm OKO CARB. IM JUSY TRYING TO GET SOME BASIC SETTINGS FOR IT. THANKS.
September 15, 20224 yr It will work straight from the box as it comes, 112 main and 48 pilot, asses after trying it, then maybe drop the needle one notch and next size up on the pilot jet if needed Assuming it's a genuine OKO
September 15, 20224 yr Author Thanks Woody, knew you’d have the info. It’s got a K44 needle, would that be right?
September 15, 20224 yr As mentioned by woody, it will be jetted out of the box. I’m using one on my 199b. I richened the needle one position and went one pilot size larger. Mine runs crisp and is nicely responsive. I felt out of the box it was perhaps a bit lean. But could just be my climactic conditions. steve Edited September 15, 20224 yr by stevem75
September 15, 20224 yr 1 hour ago, chappo said: Thanks Woody, knew you’d have the info. It’s got a K44 needle, would that be right? Yes, that's what all mine have come with
September 17, 20223 yr Just a question relative to this post. Where in the UK is the place to get a Genuine OKO Carb from Please?
September 17, 20223 yr 34 minutes ago, Old Gezzer said: Just a question relative to this post. Where in the UK is the place to get a Genuine OKO Carb from Please? Nowhere in the UK, available from Scooter Assassins in Taiwan from their ebay shop, but no longer the cheap option they were, now almost £100. Anything for sale in the UK for substantially cheaper are copies
September 17, 20223 yr There is an OKO dealer in Australia who apparently is easy to deal with, you can also search for a Keihin PWK 28 which is what the OKO is a copy of
September 17, 20223 yr http://www.mid-atlantictrials.com/Sales.html Roger is most helpful JJH needle for 325
December 16, 20223 yr On this subject I am rebuilding a Bultaco198B what settings (jets) will be needed with a OKO carb? Thanks in advance.
December 18, 20223 yr On 12/16/2022 at 8:46 PM, rumptons said: On this subject I am rebuilding a Bultaco198B what settings (jets) will be needed with a OKO carb? Thanks in advance. As per the 198 from the original post, they are the same engine. New they come with 112 main and 48 pilot and K44 needle. They run well straight off on these settings so it's just a case of a small tweak on individual bikes to get to how you want it, maybe 50 pilot and drop the needle a notch. Some use JJH needle which is slightly weaker low down, I can't really notice any difference, dropping the K44 seems to achieve the same
