Stripped head bolt
Hi all , stripped one head bolt on beta 300 2t is helicoil the only answe for repair ,
Thanks
Thanks
hi ive fixed them in the past  before with helicoil  but if i remember they are a 7mm thread
Hi , yea 7 mm pal , maybes thought there would be another soloution instead of helicoil
Nothing wrong with correctly installed and loctited helicoils, lots of misinformation about them.
Couldn't agree more, used them loads of times and are standard fit on some applications that I can think of.  M7 kits are quite cheap but would stick with either Re-Coil or V-Coil for quality....  e.g.https://www.lawson-his.co.uk/recoil-35078-replaces-35070-pro-xl-m7-x-1-0-metric-coarse-thread-repair-kit   p.s shouldn't need loctiting either. IMHO
Edited by lsv
ps
Thanks very much lads for advice 👍
:agreed:
I am sure they are great sometimes.
But every time I come across one, it is when one falls apart or comes out on a bolt from something that has been previously repaired by someone else.
I find if they haven't been loctited then they just come out with the bolt every time you undo them
I find helicoils fragile to be honest , and much prefer thread inserts that are a solid one piece of metal
This is not misinformation, it is real life experience over decades
But , I am glad they work for some people
Edited by djr
spelling
