Beta EVO 300 4t Throttle
Previously rode a Cota 4rt and just moved to a 2023 EVO 300 4t.
My Montesa had a fast throttle. I'm wondering what the 300 comes with stock. Off the throttle, the 300 feels sluggish compared to my Cota. Thoughts?
Should I install the domino fast throttle?
My experience with the Beta is they are lacking compared to the Mont in power, so it would feel sluggish in comparison.
Obviously if it has the slow action tube fitted that wouldn't help matters.
The 4T has it`s own throttle. You want more power buy an arrow exhaust and use the clutch!
 P.S. Its a vacuum style carb. Like a street bike.
Edited by lineaway
Earlier Beta 4ts had a slightly quicker throttle, at least in the initial stage.  I think the change happened around 2019.  I have a 2016 and when I went to the later throttle is made operation with small throttle openings easier to control.  I'm not sure if you can still get the old model from Beta.  However, when looking for a replacement tube for my 2016 throttle, I found that the one used on KTM 50 4t was exactly the same.  This may be it but the description is odd.
https://dominoracing.com/shop/off-road/domino-4t-throttle-system/
https://dominoracing.com/shop/off-road/4t-spare-parts/
Someone mentioned they added the pipe from the EVO 4t Factory edition and it did the job but I can't seem to source it anywhere.
I understand using the clutch. I just wasn't prepared for the difference in handling so I'm doing want I can to add a little zip.
